two diff front tires!!! help
Old Sep 23, 2002 | 12:06 PM
BlueS2000Boy's Avatar
Default two diff front tires!!! help
recently i had a hole in my passanger side front tire. i didn't want to patch because i just feel better with a new tire. a friend of my father owns a body shop so he ordered me a new tire he got it the same day. the problem is i didn't realise that the driver side is a w rated tire my new passanger side is a z rated tire. other than that its the same s-02's the stock has a flat side wall as the new tire has little groves all around the side wall. how bad is this. should i just get a new tire again? or will it not affect me that much? thanks for the help
Old Sep 23, 2002 | 01:21 PM
Schatten's Avatar
what kind of tire did they put on? S02 pole position? S02 Honda OEM? S02 Porche OEM?
Old Sep 23, 2002 | 02:18 PM
they put on i'm guessing what would be the porsche oem because it is a regular s-02 but it is z rated and has a different sidewall
Old Sep 24, 2002 | 08:53 AM
S2KYSK's Avatar
Bridgestone Potenza S-02
205/55WR16 89W SL Honda S2000 140 A A
1279lbs.
44psi
10/32nds
5.5-7.5"
6.5"
8.1"
7.1"
25"
833
205/55ZR16 SL N3 (Porsche OE) 140 A A
1279lbs.
44psi
10/32nds
5.5-7.5"
6"
7.8"
7.2"
25"
833
Looking strictly at tire specs, you shouldn't worry about it.
Old Sep 24, 2002 | 09:44 AM
Jim@tirerack's Avatar
Former Sponsor
It also has a different internal construction. I would not recommend mixing the tires. You can end up with some unpredictable handling. The OE S2K tires also have different rubber compounds on the tire.
Jim
Old Sep 24, 2002 | 09:49 AM
thanks for the help guys, i am going to have them get me the oem honda tire.
Stoic
Aug 6, 2015 01:18 PM
negcamber
Oct 24, 2003 08:53 AM
Kumori10
Aug 22, 2002 11:41 AM
John David
Aug 30, 2001 07:43 AM
andrewewing
Jul 9, 2001 08:34 AM
