UK Alignment for MY04
searched & I came across these specs for UK wheel alignment seems to be noted for MY00-03...
Can someone please let me know if these specs are applicable to MY04/05?
also can you please let me know what the downside is for this alignment spec? tire wear versus quicker response feel etc?
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6
Front
Caster Left 6
I had my MY04 set to UK specs soon after I bought it. Handling is a lot better than the factory alignment. I am still not happy with the initial turn in on the car, but I think it might be inherent in the RE050's.
I am noticing a slight increase in wear on the inside rears, but not very much at 4400 miles. The fronts are wearing flat.
I suggest you try the UK alignment and adjust from there as needed.
Make sure you take it to a shop that does custom alignments, otherwise you might get some dufas that will smile and nod and then set it to what he or she thinks is best.
is this a universal alignment spec?? can you use this on any S2000? I have a Ap1 and never got my car aligned after i dropped it. I just got some new tires yesterday and i think i should get an alignment. any advise would be appreciated.
zeroptzero
Apr 19, 2015 04:07 PM
mikecl713
Apr 3, 2004 07:24 AM
