UK Alignment for MY04
Old Jan 4, 2005 | 02:34 PM
Nate03's Avatar
Default UK Alignment for MY04
searched & I came across these specs for UK wheel alignment seems to be noted for MY00-03...
Can someone please let me know if these specs are applicable to MY04/05?
also can you please let me know what the downside is for this alignment spec? tire wear versus quicker response feel etc?
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6
Old Jan 4, 2005 | 03:44 PM
FO2K's Avatar
I had my MY04 set to UK specs soon after I bought it. Handling is a lot better than the factory alignment. I am still not happy with the initial turn in on the car, but I think it might be inherent in the RE050's.
I am noticing a slight increase in wear on the inside rears, but not very much at 4400 miles. The fronts are wearing flat.
I suggest you try the UK alignment and adjust from there as needed.
Make sure you take it to a shop that does custom alignments, otherwise you might get some dufas that will smile and nod and then set it to what he or she thinks is best.
Old Jan 4, 2005 | 03:46 PM
FO2K's Avatar
BTW, my rear toe is set at 1/4 inch (in). I think that is the UK spec in inches.
Old Dec 2, 2005 | 08:40 AM
xxjdxx's Avatar
is this a universal alignment spec?? can you use this on any S2000? I have a Ap1 and never got my car aligned after i dropped it. I just got some new tires yesterday and i think i should get an alignment. any advise would be appreciated.
zeroptzero
Apr 19, 2015 04:07 PM
AZS2KDancer
Feb 18, 2013 12:56 PM
d0nkeyxPunch
Feb 8, 2007 02:45 PM
s2kdriver80
Apr 10, 2004 04:05 PM
mikecl713
Apr 3, 2004 07:24 AM
