Volk GT-C + Endless BBK clearance. NEED HELP!
Im planning to get the Endless BBK, and I want to get the Volk GT-C. The size rims i want are 18x8.5 in the front and 18x9/9.5 on the rear. can you guys tell me what offset do i need? also would you guys recommand 18x9 in the rear or 18x9.5? also will i need to roll my fenders a lot? thanks. any help will do
To help you and others who answer this question out. Here are the available sizes and offsets --> http://www.mackinindustries.com/md/rays/Re...tc_spec.jpg.gif
They do not make a 18x8.5 or 18x9.5 rim in this style. Also you are going to have a hard time getting Endless brakes to fit as they are huge without wider fenders. These rims are also heavier than stock so performance will be impacted slightly.
You oviously want aggressive so how about 18x8 +42 (high type) and 18x10+47. You WILL need a fender roll, large amounts of neg camber and stretched tires. You may even need a spacer to fit your brake kit. Others may chime in but here is atleast a starting point.
lol.
first: they dont make 18x8.5 or 18x9.5.. only make 7.5/8/9/10/11 (Face1)
for endless ud need face 1 and A disk 8+42. and i really dont think it will clear still. the endless are HUGE brakes. it might need a 5mm spacer which will turn +42 into +37.
as far as the rear, all the face1/face2 offsets are agressive..for a 9" the lowest offset i see is 42.. which is 20mm further out than a safe fitment (almost an inch)
to sum a long story short, they wont fit. the ONLY wheel ive seen fit endless on stock fenders w/o having a crazy offset is the Work Meister S1 3 piece. or i think the prodrives with a small spacer work.
Face1
http://www.rayswheels.co.jp/cgi-bin/cgi2/s...modelName=GTC_1
Face2
http://www.rayswheels.co.jp/cgi-bin/cgi2/s...modelName=GTC_2
Face1
Face2
You'll get the deep dish look like you want with them too.
PM rijowysock ( https://www.s2ki.com/forums/index.php?act=S...=0#entry8956289 )
RGII with endless nope! won't fit....
RGII 18X7.5 ET48 won't fit any BBK kit
RGII 18X8 ET45 will clear Stop Tech and other similar BBK kits but not endless
I purchased a set and had to return them becuase my RG's don't fit any thing
grrrrrr... on a forum topic.. someone said Advan RG2 18x8 +45 clears Spoon, Brembo, Stoptech, and Endless with no spacers. is that wrong?
heres the forum
https://www.s2ki.com/forums/index.ph...c=338881&st=25
heres the forum
