Want Wider Thread Patches?
Old May 7, 2008 | 07:59 PM
xDeLiRiOuSx's Avatar
Default Want Wider Thread Patches?
spent the last two days going through the old topics so I am familar with the Lingos. I never got the answer I was after so I am going to make a thread here to ask it directly. I am almost ready to pull the trigger and order a set of RE050 A PP for the Rear (245/40R17 ).
I have a 2007 S2000 with stock tires.
I use it for daily driving and occasional spirted drive. I do drive in the rain and want good control in the rain.
Will I have the same thread with for the same given tire spec (ie rear 245/40R17) if I go RE050 vs RE050 A PP?
I heard SOOO many threads about people wanting to go wider (ie 255/40R17)! Is that because it's cheaper (currently is at Tire Rack)? Or is there any improvement? What advantages/disadvantages are there? (this is so uncleared from all the reading I've done).
Thanks,
David
Old May 7, 2008 | 08:21 PM
Hrm, I think I answered my own questions by looking at the specs on tirerack.com
the 245/40R17 RE050 specs are:
Section Width: 9.6"
Thread Width: 9"
The 245/40R17 RE050A PP specs are:
Section Width: 9.8"
Thread Width: 8.7"
Hrm, are the RE050 A PP much of an improvement? Would it make more sense just to get the stock size, stock tire (RE050 245/40R17?)
Thanks,
David
Old May 8, 2008 | 03:43 AM
So the question now is, what disadvantage/advantage will the slightly wider thread width of the RE050APP have on the car?
And, why would someone go all the way and get some super wide as the 255/40R17?
Thanks,
David
Old May 8, 2008 | 01:38 PM
Jim@tirerack's Avatar
Former Sponsor
The 255/40R17 work well in the RE050A Pole Position be cause the front tires are wider than the OE tires.
Old May 8, 2008 | 08:24 PM
I see, so tire size would you recommend for the fronts if I get 255/40R17 for the rears?
By the way, the deal that expires on May10, is it valid if I get a pair of front and a pair of rears?
Thanks,
David
Old May 9, 2008 | 06:44 AM
my2ks2k's Avatar
225/45/17 for the front
Old May 9, 2008 | 10:57 PM
^ cool! Thanks.
So, it all comes down to: "What's the advantage of having a wider thread patch?"
--David
Old May 10, 2008 | 01:11 AM
modMonkey's Avatar
Originally Posted by xDeLiRiOuSx,May 9 2008, 10:57 PM
^ cool! Thanks.
--David
Are you asking that as a question?
Old May 10, 2008 | 02:15 AM
ZDan's Avatar
What the hell is a "thread patch"?!
Old May 10, 2008 | 02:17 AM
modMonkey's Avatar
prob. meant contact patch
