What is the advantage of running larger wheels
Old Jul 3, 2006 | 07:20 AM
HiPER's Avatar
Default What is the advantage of running larger wheels
Obviously, I am a suspension n00b. I know the NSX runs 18s in the rear and 17s in the front. What is the advantage of this? Why don't many people on here do it?
I understand staggered vs. non-staggered but not this.
Thanks in advance
Old Jul 3, 2006 | 08:11 AM
vtec9's Avatar
mainly because it looks cool one advangate would be stiffer sidewalls on lower profile tires which leads to less tire flex on cornering
Old Jul 3, 2006 | 08:37 AM
Ek9's Avatar
Ek9
Banned
For me, the only reason to consider it, is because, you need 17" for big brake kits and the availability of tires is better for 17" over my stock 16's.
The downside is, it they weight more and as the profile of the tire shrinks, the ride gets stiffer.
Old Jul 3, 2006 | 10:07 AM
NFRs2000NYC's Avatar
The advantage is to run a wider tire. Some people get a larger wheel (18s, or 19s) but get the same width as stock. IMHO thats stupid, but whatever floats your boat. However, with a wider tire, you are improving, grip, ride quality, and traction.
Old Jul 3, 2006 | 10:16 AM
vtec9's Avatar
wheel diameter has nothing to do with wheel width, and therefore tire width, unless dependent on manufactured tire sizes. the NSX doesn't run 18s in the rear to accomodate a wider tire.
Old Jul 3, 2006 | 08:11 PM
rijowysock's Avatar
nsx runs larger rear for less tire flex because of added weight.. thats what i heard
Old Jul 4, 2006 | 01:25 PM
sahtt's Avatar
It depends on the setup the engineers wanted to achieve. There is no one reason why staggared setups are better or worse than non-staggared. However, on most sportscars, even fwd ones, a slightly smaller front wheel diameter can benefit most cornering properties. That being said, if you are already rolling on 15's or 16's, this isn't aimed at you.
The bottom line is the larger rear wheels was developed/used to accomodate larger width tires in the back for traction. The same principles were not needed up front, so the staggared setup was born.
sahtt's Avatar
And on that topic, most of these cars with 18's and 19's stock would benefit from moving down to 16's or 17's in almost every performance catagory, all else equal.
johnfrey_s2k
Jun 15, 2016 12:25 PM
Mark355
Apr 18, 2009 07:23 AM
goneverything
Dec 10, 2004 03:30 AM
2Ting
May 21, 2003 01:13 PM
bkw
Aug 10, 2001 03:46 PM
