What Wheels Available in 17"? Help?
Old Apr 24, 2008 | 01:30 PM
1nate7's Avatar
Those Work Emotions are nice wheels, you can't go wrong with them. They are available in 8" +47 front and 9" +44 rear. With the negative camber you are running they should fit fine, especially if you are at stock height.
Old Apr 24, 2008 | 01:31 PM
gotswap's Avatar
The wider the wheel the higher offset needed ex 17X7 et40, 17X7.5 et45
IMO the RPF1 have an aggressive offset 9 et 45, I had a set of works 9" with a 51 mm offset stock height and alignment and the lip was slightly outside the fender.
Old Apr 24, 2008 | 05:11 PM
///MIKE's Avatar
Thanks for the responses. I really like the Work Cr's because they resemble the stock wheels but shave some weight at the same time. Does anyone know off the top of their head which weighs less? RPF-1's or Work Emotion CR's?
What is just as important to me is the width and profile of tires that I can run. Will either of these wheels at the offsets listed support 225's in front and 245's in rear?
Thanks again!
Old Apr 24, 2008 | 05:43 PM
BB_S2K's Avatar
Work Emotion CR Cast 17x7 19.0
Work Emotion CR Cast 17x8 20.0
From here: http://www.wheeldb.com/work-wheel-weights-p-5484.html
Tirerack has the following for RPF1's:
17x7.5 15.0
17x8 16.0
Gives you a general idea of what to expect in terms of weight. I think those sizes will work, but I don't know much about that so I'll let someone else answer that.
Old Apr 25, 2008 | 09:19 AM
KnowledgeIsPower's Avatar
GTmotoring.com for rpf1. greg is the man
Sylvain2000
Aug 27, 2018 05:19 AM
hadeediqbal10
Sep 9, 2013 09:09 AM
iam_ultrasonic
Aug 18, 2011 05:50 PM
jdm s2k
Jul 15, 2005 06:13 PM
KeithD
Oct 18, 2001 03:11 AM
