What will be required to make these fit?
Old May 18, 2012 | 06:11 AM
GerardoCastillo's Avatar
Default What will be required to make these fit?
I just bought some CR Kai's and wanted to know what I'm going to be looking at as far as fitment goes. Any input is appreciated. I know i will have to roll fenders but aside from that, what else would have to be done? Measurements are 18x9.5 +38 5x114.3 all the way around. Thanks!
Old May 18, 2012 | 06:25 AM
S2k007's Avatar
If you want to run proper side tires (at least 255s), you'll need more than a roll. Likely a pull both front and rear and good amount of camber.
Old May 18, 2012 | 06:31 AM
Yea, i want to run proper size tires to avoid any issues later on.
Old May 21, 2012 | 08:06 PM
sto405's Avatar
Hard roll and medium pull, rear bumper tab relocated and previous location bent flat, trim the rear bumper a lot, and for the front say good bye to your factory lines as you have to roll them pretty much flat from the middle to the back towards the door, and just take off your fender liners as you'll probably rip them off if you don't. What I just told you should let you fit any 245, and some narrow 255 with about -1.8f and -2.8 caber out back
Old May 22, 2012 | 06:55 PM
Mark355's Avatar
Ask yourself if it's worth the trouble and irreversible mods to your fenders to run these wheels.
habbibaS2K
Jun 6, 2013 02:26 PM
iDomN8U
Jul 16, 2012 08:36 AM
Rxmfn7
Jun 10, 2008 07:06 PM
JBrakeS2K
Dec 23, 2007 09:57 AM
