wheel help ASAP PLEASE
Old May 31, 2013 | 10:59 PM
habbibaS2K's Avatar
Default wheel help ASAP PLEASE
Hey guys. I found a set of wheels I want but idk if theyll fit there
18X8.5 35etfronts
18X9.5 40et rears
73.1 center bore
I wanna know if theyll fit properly and what tire size I should go with. Please help me out
Old May 31, 2013 | 11:18 PM
Manga_Spawn's Avatar
Site Moderator
Not without a serious fender roll tab relo and a good alignment. It is possible but it won't be easy. Tires a 225 up front and a 255 for the rear. It's doable you just have to make sure these things are done correctly.
s2000Junky's Avatar
The fronts are more aggressive fitting, and will require a roll plus a bit of a stretch on the tire to clear safely, so 215's. You can fit more rubber up front if you plan on pulling the fenders, but 235/40 would be about it. The rears you can fit a 255 with just the basic roll and bumper tab relocate. Make sure your camber is at least -2 up front and -3 in back.
Old May 31, 2013 | 11:20 PM
s2000Junky's Avatar
haha Manga beat me to it.
Old Jun 1, 2013 | 10:46 PM
habbibaS2K's Avatar
What do you mean by a seriouse fender roll? I just had the car repainted and rolled and tried pulling the fenders too but worried what you mean by seriouse?
Old Jun 2, 2013 | 10:02 AM
Site Moderator
They need to be rolled flat. You will be able to make up any lack of flare by running more camber.
Old Jun 2, 2013 | 08:14 PM
habbibaS2K's Avatar
Will that kill my tires if I run more camber?
Old Jun 3, 2013 | 02:31 AM
ZDan's Avatar
Find wheels with more offset.
Old Jun 3, 2013 | 05:55 AM
baZurk's Avatar
You should be fine with the camber. Just make sure that when you get an alignment that your front toe is set to 0 and the rear total toe is no more than a quater inch.
I am unsure how much camber you will need but it all depends on ride height.
Old Jun 4, 2013 | 11:48 PM
habbibaS2K's Avatar
Ive been busting balls trying to find a higher offset on wheels for the s2k and no luck. But same time I dont want to spend so much money on wheels.
