Wheel offset
My fenders are rolled and rear tab is relocated, with that being said I plan on running 18x8.5 in the front and 18x9.5 in the rear. What offset should I go for in the front and rear as well as how much camber should I run? Thanks in advance and sorry for not being that educated on offset, it's super confusing and I can't find a solid forum to point me in the right direction
Well there is a range, depends on what width tires you are planning to run, if you are looking to accommodate a BBK, or a particular stance. I can start with tire sizing, as in an 8.5/9.5 stagger would generally be a 225-235F/255R stagger for a good optimized tire profile. With that combo your offset range fitment would be +45 to +65 front to +40 to +80 rear. Less numerical offset to push the wheel closer to fender, higher to push in.
