Wheel Spacer
Old Dec 30, 2004 | 09:31 AM
pepelepew916's Avatar
Default Wheel Spacer
Some friends of mine owned VW and they use spacers for their rear tires. They said it handles better and look nicer too. Just wondering if anyone have any input or experience of using spacer for the front/rear and what size? Thanks.
Old Dec 30, 2004 | 09:55 AM
Chazmo's Avatar
I don't think anyone can give you a clear answer to this question skunk-man .
Are you talking about stock wheels? If so, '04+ or 00 - 03?
Hub spacers are often used to size various wheels to the car. If you're more specific, more people may respond. Also, check the wheel and tire forum.
Old Dec 30, 2004 | 10:03 AM
sorry! it's stock wheels on MY01.
Old Dec 30, 2004 | 08:41 PM
Stealth Operator's Avatar
People generally use spacers to clear bigger brake calipers or to "push" the wheels out more. If it's option one, it's really not much of a choice, but if it's option 2, it's a compromise of budget to now buy the correct offset of wheels. Whether if it's an improvement to handling, is only up to one's intepretion.
Nothing wrong with the OEM setup/layout. Look for other options to improve handling instead of this.
Old Jan 1, 2005 | 02:43 PM
mschlocker's Avatar
I have done this on my MR2. I actually bought wheels to fit an S and spaced them out for the two. Planning ahead here. I also use these spacers on the track with my stock wheels. Can't really notice a handling difference. I think the wheels spaced out look a little better though. When ppl buy aftermarket wheels for the S they have a smaller offset which effectively spaces them out more. You can add spacers to obtain the min offset that people use on the S (46 I think). If you go with larger than 3mm spacers you will need to replace your wheel studs with bigger ones. You can also get really big spacers that bolt on and have their own studs.
Final word. I wouldn't waste my time / money on this.
Old Jan 1, 2005 | 11:01 PM
vtecvoodoo's Avatar
I run spacers in the rear (5mm) to clear a big brake kit. Had to install longer studs, which was pita. We sell a ton of the for the Mustang, VW`s, etc. Not too many Honda kits though. I think the stock setup is fine, I`d only use spacers if I had to...
Ryan
simons2k
Jun 4, 2013 06:14 PM
mph2k
Mar 17, 2009 10:49 AM
STAIN
Aug 12, 2008 01:41 PM
SoCalIsMyLife
May 2, 2007 05:52 AM
