Wheel Spec fitment
Old May 5, 2010 | 11:55 PM
STAIN's Avatar
Default Wheel Spec fitment
Hi, I would like to run the following im running coils on very stiff settings,
Id like to run these specs and want to know if its humanily possible.
Front:17 x 9 +45 245/40 -1 deg camber
Rear:17 x 9 +35 255/40 -2.5 deg camber
My car isnt super low I can raise or lower just want to know if these wheels will be a problem, my rears guards are lipped and suspenssion is very stiff also.
thanks.
Old May 6, 2010 | 08:20 AM
B serious's Avatar
lol...yes that will be a problem for sure on stock fenders in the front. Unless you're at stock height or something. The rear should be fine...but you might have to roll the fenders and relocate the bumper tab.
How low is "not that low"? And what type of driving do you do? Track? Just DD? This type of question requires a lot of specific details.
Old May 6, 2010 | 10:37 AM
nitewing117's Avatar
You'l need to roll the rears and relocate the bumper tabs with -2.5 deg. I rubbed running 17x9 +45 w/ 255's and that same amount of camber until i completely trimmed the bumper tab.
Old May 6, 2010 | 04:37 PM
STAIN's Avatar
B_seriouis, I will be tacking it to the track.
nitewing117, do you run 255/40 on the front ?
Im prob 1.5inch's lower then stock height.
Old May 7, 2010 | 05:53 AM
1nate7's Avatar
More negative camber in the front (at least -2) will give you more clearance and also better handling.
Old May 7, 2010 | 10:58 AM
17x9, 255/40 up front. I had to flare my fronts to get the 255's under there and not need to run a ridiculous amount of camber. My latest numbers were -2.2 deg in the front.
I'm also dropped 1.5".
Old May 7, 2010 | 06:13 PM
STAIN's Avatar
thanks guys.
rdk
Oct 18, 2012 06:04 PM
allHAWKedup
Oct 23, 2011 08:50 PM
hellspare
Apr 18, 2011 11:09 AM
icqlite_hk
Sep 30, 2009 03:28 PM
oranje
Dec 17, 2008 05:01 PM
