Wheel stagger
Im trying to pick out the rims I want but I got this question.I have a 00 S2000,I was looking for the confirmed answer on the most wheel stagger that will fit without modifcation to the fenders,I want to put 18s and no bigger.
This sounds more like an offset question than a stagger question. 8" front, 9" rear is very common. If you don't want to roll the fenders, look for offsets around +55 or higher. The wheel fitment sticky on the top of the forum is a good guide. You can see what offset will work without rolling the fenders for a variety of wheel/tire widths.
You can go really wide on the wheels as long as the offset is high enough. Then it depends on the width of the tire and your alignment specs as to what will fit. Just try to go to mid 50's to mic 60's on the offset.
