Wheels?
My track wheels. 17x9 +45 all around.
Look at any RWD sports car, Super cars in particular, the rear is always more concave then front, front is always a narrower wheel/tire then rear and also needs more room for a larger caliper, so the concave/convex staggered fitment is very much inline with that look and practicality, and it does just accentuate the rear that much more which is the more desired look on a RWD car. Running concave all the way around looks like an AWD/Subaru set up. Doesn’t really fit the character of the S2k INMO.
I would totally agree with you if the convex/poke of this wheel was on the rear. Ive seen that before and it doesnt look good at all.
Then again running a square fitment has to break this mold, but I don’t run a square fitment on a RWD car that on a stock body can accommodate 40mm more rubber in the rear then front, that’s why I run the better option of 255/295
Originally Posted by blueprint' timestamp='1437584139' post='23689198
Looks good but im not feeling the poke of the 8" RPF1.
I also think it looks better but thats my opinion as well and im sure most will agree with me in terms of the RPF1.
Work Options
M.C.O Racing Type CS 18x9.4 +42 is doable for the rear
http://www.workwheelsusa.com/product...=50&wheel=1019
http://www.workwheelsusa.com/media/w...9/MCO_2014.pdf
Emotion CR Ultimate 17x9 +38 is doable for the rear.
http://www.workwheelsusa.com/product...=27&wheel=1003
Forgestar wheels
http://www.forgestar.com/v2/wheels.php
Other Enkeis everyone forgets about
RP03
http://enkei.com/shop/racing/rp03/
PF07 (Is this new? never seen this wheel)
http://enkei.com/shop/racing/pf07/
TS9
http://enkei.com/shop/tuning/ts9/
Kojin
http://enkei.com/shop/tuning/kojin/
Wedsport
TC105n (17x9 +35 is concave and has been run ont he rear of the S2000 front would be flat face)
http://www.evasivemotorsports.com/mm...de=WEDS_TC105N
There is plenty more. Search some more and don't be so impatient. There are options out there but it takes time to research them and track down the set you want.
Forgestar wheels
RP03
TS9
Kojin
Wedsport
Originally Posted by s2000Junky' timestamp='1437588468' post='23689285
[quote name='blueprint' timestamp='1437584139' post='23689198']
[/quote]
You meant "over steer" for your square set up, i think? But depends on how you have your suspension tuned also. Typically a square set up on this car lends itself to easy over steer situations, not the other way around. But anyway, don’t mean to derail this thread here.
That would be a better argument if there was more than one maker of your preferred tire size. One reason I wound up at 245/255 is because both of those sizes are available from a wide variety of makers in very sticky compounds.
18 is the way to go if you are going wider than 255. Lots more options thanks to porsche using those sizes on quite a few cars. Tires cost more but hey if this was cheap or easy then everyone would do it.
I have noticed the guy with my old car would rather stance it on XXR's, so I'm going to see about getting those CE28's back.
17x8 +38 with 235/40 Federal 595 RSR. Not ideal, but better than what I have now?
