where can i get Hubcentric Wheel Spacers?
I did a search on this, but didn't turn up alot...i found that H&R makes some nice hubcentric spacers...but where can I get them from? Also, are there any other brands that make hubcentric spacers?
any info is appreciated
Originally Posted by s2k dre,Jan 17 2008, 12:33 PM
h&r is the only ones that i've seen! other spacers like kics and ichiba have hub centric rings sold separately, what exactly are u tryin to do?
i've checked the sponsors...haven't seen anyone that carries the H&R ones yet. Seems the ichiba spacers are hubcentric for the rear wheels only...
If you go 10mm or bigger, you will need to swap the oem studs with the longer studs that come with the kit. I just did it less than a month ago and it is a pita replacing the wheel bearings.
Originally Posted by S2Kart,Jan 18 2008, 06:04 AM
I've got 5mm spacers in the back. I would not go any bigger than 5mm without replacing the studs with longer ones.
