Why run 225/45/17 in front?
Old Sep 14, 2005 | 07:01 PM
eMokhtarian's Avatar
Default Why run 225/45/17 in front?
What's the purpose that they run 45 profile tires in the front, instead of 40.
Any disadvantage or handling alteration on a 225/40/17 set up in the front?
Any feedback is appreciated... Take Care.
-Ed
Old Sep 14, 2005 | 07:45 PM
Mark B.'s Avatar
eMokhtarian:
It has to do with using a wider tire on the back.
To keep the overall diameters about the same and the RPM about the same, a larger profile must be used on the front.
Stock size
215/45/17 RPM 840 Outside diameter 24.8"
245/40/17 RPM 847 Outside diameter 24.6"
Lower profile
215/40/17 RPM 875 Outside diameter 23.8"
Regards,
Old Sep 14, 2005 | 07:48 PM
xviper's Avatar
Who's "they"?
The idea is "mostly" to approximate the OEM wheel/tire diameter and "partly" for looks. A 40 aspect ratio here would make for a smaller diameter. This changes the way the car turns (maybe a little better turn in and perhaps a little less lateral grip) and it makes for more space between the top of the tire and the bottom of the fender.
Old Sep 14, 2005 | 10:24 PM
I see.. Thanks for all the feedback... I have a better understanding now.
Any more will be appreciated...
Take Care,
Ed
Xeon
Jan 16, 2017 09:12 AM
s2kpotenxixe
Aug 24, 2016 02:06 PM
jchan727
Aug 26, 2012 07:22 PM
AndyThomason
Jan 20, 2009 12:31 AM
jlucas
Sep 1, 2004 05:51 PM
