Why Square when Factory Stagger?
Originally Posted by ZDan' timestamp='1344435484' post='21921548
Why it makes sense: If you add wide tires up front without changing roll stiffness bias, you aren't fully utilizing that added grip up front.
Even if you go with "too thick a sway bar", you haven't canceled the mod, you *still* will have more overall grip, it will just be biased more to the rear and you'll get more understeer.
If you take a car that has good handling balance and add a ton of front grip, you're no longer balanced. Bias roll stiffness to the front a bit and you'll still have more grip up front vs. originally, and also have more rear grip. For me, sway bars are *the* way to balance grip after you've got appropriate camber levels and spring rates.
Problem with the S2k is that to go wider than 255 in back, you have to go taller as well, which hurts gearing.
255 up front 295 back /thread
Run the appropriate spring rates and settings on your coilovers and chances are good your not going to find any short comings with the sway bars that came on your S.
Originally Posted by s2000Junky' timestamp='1344530688' post='21924729
[quote name='ZDan' timestamp='1344435484' post='21921548']
- Wrong, your reducing G load on the tire with the most grip and maintaining it over the inside wheel which has the least grip, effectively biasing the weight on the least effective side of the car under load. more weight transfer is good for max traction, it isnt good for handling control however, the "right" balance is preferential and so is how much of this balance you want front to back as well as side to side. You’re forgetting what the side to side does I believe in total available traction. For example, Drag cars don’t run stiff suspension in the rear to gain traction, they want maximum weight transfer to the rear of the car meaning less spring weight for traction. The same applies in our case during side load cornering/sway bars.
-I don’t drive fast nor do I track in the rain, so rain traction means little to me. Yes my mistake 40mm per tire wider.
I'm not N/A but am from time to time when the FI has issues, I think I would still choose this size, just from the sheer grip it provides in the corners and not finding any draw backs since the overall gearing hasn’t changed. The XS is actually quite a light tire for its size, coupled with very light wheels RPF1, the over all package is on par with OEM weight.
[/quote]
Originally Posted by ZDan' timestamp='1344534943' post='21924943
Adding a thicker front sway bar doesn't "remove weight transfer".
Thicker front sway will transfer MORE load to the outside front, taking more load off of the inside front. This will act to reduce total front grip.
You can affect how much is reacted up front and how much in the back, though, which allows you to tailor handling balance. Stiffer front bar reacts more of the cornering load *reducing* front grip.
Stiffer front bar => more load on the outside front, less load on the inside front, which reduces total front grip. This is because the load/grip curve is not linear. The additional load on the outside front doesn't give as much lateral grip back vs. what is taken away at the inside front, because the outside front is more highly loaded.
Stiffer front bar => LESS load on the outside rear, MORE load on the inside rear. Which INcreases total rear grip, as the reduced load on the outside rear allows it to make more grip per load, and the inside rear is also able to contribute more additional grip.
Originally Posted by c32b' timestamp='1344492715' post='21923821
What alignment do u run?
-2.3, 0 toe
Rear:
-2.8, 3/16" toe-in
On the rear, I do get more inside wear than outside. On my next alignment, I'm probably going to go back to 1/8" toe-in on the rear as I've been adjusting my suspension setup and it's a little on the tight side. Going back to 1/8" should help with the rear wear a bit. Right now, the insides of the rears are about bald and I have maybe 2mm of tread left on the outside of the tire. It has been about 8k miles or so since I last rotated front to rear, so the front wear is more even across the width of the tire; i.e. still tread left on the insides.
btw, what r ur spring rates?
Originally Posted by s2000Junky' timestamp='1344540555' post='21925241
[quote name='ZDan' timestamp='1344534943' post='21924943']
[/quote]
ok
I run non-staggered to get rid of the increadible amount of midcorner (steady state) understeer. I am running 255s square RA-1s for the track & 275s square Hoosier A6 for auto-x. It's rare that I take the track car to the auto-x, but I still get a slight push with my set up. And this is probably due to my lack of patience on long sweepers.
My alignment on the track car is..
Front -3.7 camber | little bit of toe out | 6.7 caster
Rear -2.7 camber | 1/8" toe in
I run non-staggered to get rid of the increadible amount of midcorner (steady state) understeer. but I still get a slight push with my set up. And this is probably due to my lack of patience on long sweepers.
[/quote]
Hi ZDan,
Tried to send you a PM but was unable to. Was trying to mention something in private to you.
