Will A 18" wheel change my stock wheel diameter?
Old Aug 12, 2004 | 10:15 PM
volcomSNOWS2K's Avatar
Default Will A 18" wheel change my stock wheel diameter?
Hey guys. I am so confused. I was going to stay with 17" Volks but I can not find any that have the actual correct offsets for the S. So I found a really nice set of wheels with the PERFECT offset. 18X8 +50 fronts and 18X9 +63 rears. I need to know now honestly, does it change my overall wheel diameter as compared to my 16" stock S wheels? If so by how much? Are the 18" diamteres going to be larger or smaller than the 16? Oh ya tire sizes will be 215/40/18 fronts and 245 or 255/35/18 rears. Any info from u S pros out there are appreciated greatly. Thanks!!
Old Aug 13, 2004 | 06:46 AM
Fongu's Avatar
First, the 17" Volk CE28N's have one of the best offset applications for a S2000. Second, the total wheel and tire diameter should be approximately the same to keep the speedometer and odometer (and probably other stuff) to stay reasonably accurate. Bigger wheel, means shorter tire sidewall to get the same overall diameter. That's the 2nd aspect ratio number in the tire spec. You can find the tire diameter specs. from the manufacturer web site or http://www.tirerack.com . I did it for you and here are the results.
OEM SO2's
205/55/16 - 25.0" diameter
225/50/16 - 24.8" diameter
Miscellaneous right sized tires
215/40/18 - 24.7" diameter
255/35/18 - 25.0" diameter
Old Aug 13, 2004 | 09:25 AM
Thanks FONGU! U the man! I appreciate the calculations!
Old Aug 13, 2004 | 08:42 PM
s2ka's Avatar
You can get the same overall diameter in 17", but it's almost impossible to get in 18". The S2000 is very sensitive to a change in gear ratio, so you will feel a decrease in acceleration if you put on bigger diameter tires.
17"
18"
Booztin
Feb 14, 2011 04:33 AM
clarkster009
Aug 18, 2010 11:15 AM
S2GeeZy
Jan 24, 2006 09:56 PM
ayelien
Jun 30, 2004 09:26 AM
bentrim
Apr 27, 2001 10:49 PM
