will 18"x7.5" +42 or +45 offset fit on a 2002 s2k?
Old Mar 1, 2004 | 07:44 AM
HighRevvin's Avatar
Default will 18"x7.5" +42 or +45 offset fit on a 2002 s2k?
hey guys I am just wondering if a 18 x 7.5 with a 42mm or a 45 mm offset will fit on 2002 s2000. I found a great deal on a set of rims and I would hate to pass it up. Will there be any rubbing issues if it is dropped 1". Your feedback is highly appreciated, thanx in advance.
Old Mar 1, 2004 | 08:29 AM
gaebril's Avatar
The wheel will probably stick out and rub into the fendor on bumbs on stock springs. God only knows how bad it would be lowered. If you do a little research you're probably going to want +48 or more.
Old Mar 2, 2004 | 04:49 AM
Sen's Avatar
Sen
a 45 will fit. Search 'konig holes' on the boards. I beliebe a member fit something like 215 wheels on 45+ rims and it fit fine even with a drop.
Old Mar 2, 2004 | 08:52 AM
gaebril's Avatar
Ya but I'd think you'd want at least a minium 225 on a 7.5 rim. Do a search on the board Rev, there's lots of good info on this topic.
Old Mar 2, 2004 | 09:21 AM
Project Dream's Avatar
18 x 7.5 with a 42mm offset running 235 tires in the rear will rub. If you decide run rims like these, your car may feel more unstable and the handling will be decreased. I have done this before.
Old Mar 2, 2004 | 09:56 AM
HighRevvin's Avatar
id really hate to pass these up, you guys should take a look and tell me if i should risk it or not. www.01designsystem.com I am interested in the 18x7.5 +45mm
Old Mar 2, 2004 | 01:12 PM
Those are some pretty nice wheels. What is the price that you will purchasing them for? The site lists the set of wheels in 18 x 7.5 for $1490 for the set. If you add just a little money up top of that, you can get a great set of Volk wheels with good offsets for the S2000 from Evolution or any of the other board sponsors.
Old Mar 2, 2004 | 01:32 PM
Jim@tirerack's Avatar
Former Sponsor
At that kind of offset the 235 will stick out in the rear.
Jim
Old Mar 2, 2004 | 02:13 PM
Sen's Avatar
Sen
there are actually lots of members with similar specs.
http://forums.s2ki.com/forums/showthread.p...t=konig+imagine this members has the konig imagines (+45) he ran 225/40 all around.
This member http://forums.s2ki.com/forums/showthread.p...t=konig+imagine even has 235 in the back with the same +45 offsets. He even lowered his car with H and R springs. And quoting him "rubbing is minimal".
Old Mar 2, 2004 | 03:25 PM
S2-Raw's Avatar
You'll be fine with a +45 offset. But if you plan to lower it, you'll need a pretty stiff suspension set up and or rolled fenders to avoid rubbing.
This guy is running +40 up front and +42 in rear on:
17X7 225/45/17
17X8 245/40/17
He says, there was rubbing until he rolled the fenders. Now he uses the car for Drift events with no rubbing at all.
Sordz
Feb 22, 2011 11:46 AM
rossco
May 30, 2009 09:09 PM
agapes2000
Jun 14, 2005 09:16 AM
turb037
Mar 16, 2005 09:04 AM
twofast4u
Jul 20, 2004 06:54 PM
