Will this fit?!?
http://www.tirerack.com/cart/HoldingArea.jsp
All your feedback are welcome.
Front:
Offset: 45mm
Backspacing: 6.18"
Bolt Pattern: 5-114
Rec. Tire Size: 225/45-17
Weight: 16.0lbs.
Finish: Gold Painted
Construction: 1pc. Gravity Cast w/ MAT Technology
Finish Warranty: 1 Year
Manufactured in Japan
Rear:
Offset: 45mm
Backspacing: 6.69"
Bolt Pattern: 5-114
Rec. Tire Size: 245/40-17
Weight: 15.7lbs.
Offset: 45mm
Backspacing: 6.18"
Bolt Pattern: 5-114
Weight: 16.0lbs.
Rear:
Offset: 45mm
Backspacing: 6.69"
Bolt Pattern: 5-114
Weight: 15.7lbs.
If you aren't lowered you could probably get away without the roll but it would be better to do it before the wheels. There is always the chance that something happens and messes up a fender. Post in your local subforum and ask where people go for fender rolls. If you haven't done it I wouldn't recommend trying it without some guidance. Plus a fender roller is not cheap so unless you want to be the fender rolling guy buying one doesn't make much sense.
