Will this fit?!?
Old May 18, 2014 | 03:13 PM
S2kmybabe's Avatar
Default Will this fit?!?
http://www.tirerack.com/cart/HoldingArea.jsp
All your feedback are welcome.
Old May 18, 2014 | 03:19 PM
S2kmybabe's Avatar
Click cart in the corner :: )
Old May 18, 2014 | 03:30 PM
Manga_Spawn's Avatar
Site Moderator
Please just put the wheel specs in the thread.
Old May 18, 2014 | 03:54 PM
S2kmybabe's Avatar
Front:
Offset: 45mm
Backspacing: 6.18"
Bolt Pattern: 5-114
Rec. Tire Size: 225/45-17
Weight: 16.0lbs.
Finish: Gold Painted
Construction: 1pc. Gravity Cast w/ MAT Technology
Finish Warranty: 1 Year
Manufactured in Japan
Rear:
Offset: 45mm
Backspacing: 6.69"
Bolt Pattern: 5-114
Rec. Tire Size: 245/40-17
Weight: 15.7lbs.
Old May 18, 2014 | 05:05 PM
Site Moderator
Will need rolled fenders and tabs relo'ed.
Old May 18, 2014 | 05:08 PM
S2kmybabe's Avatar
Hard job?
Old May 18, 2014 | 05:11 PM
JamesFM's Avatar
You will want to have it done professionally (or by someone who has done it a few times). A fender roll with the bumper tabs relocated will usually cost around $250.
Old May 18, 2014 | 05:17 PM
S2kmybabe's Avatar
But it Will fit until i get my suspension/drop...
Old May 18, 2014 | 05:35 PM
S2kmybabe's Avatar
On stock ap1(nô drop)?
Old May 19, 2014 | 08:37 AM
Site Moderator
Man I don't charge enough.
If you aren't lowered you could probably get away without the roll but it would be better to do it before the wheels. There is always the chance that something happens and messes up a fender. Post in your local subforum and ask where people go for fender rolls. If you haven't done it I wouldn't recommend trying it without some guidance. Plus a fender roller is not cheap so unless you want to be the fender rolling guy buying one doesn't make much sense.
