Will I Rub(18"Prof with eibach/koni)
Old Feb 15, 2005 | 08:21 PM
04RioS2k's Avatar
Default Will I Rub(18"Prof with eibach/koni)
Hey I'm planning on getting the 18inch professor and was wondering would I rub with my eibach/koni spring/shock combo which drops around 1.25-1.5 inch? If not then what would be the best tire size for this application? Anyone with any advice, thanks.
John
Old Feb 16, 2005 | 10:00 AM
dispader's Avatar
What offsets and sizes are the Proffessors?
Old Feb 16, 2005 | 10:03 AM
Jim@tirerack's Avatar
Former Sponsor
I would say you would probably have to roll the fender lips and run a little more negative camber. I would also say stay a little on the narrow side on the tires.
If I can help let me know.
Old Feb 16, 2005 | 12:29 PM
ASMspec's Avatar
We need offsets and sizes in order to get you a real answer. With that very minimal drop you should be fine but again we need sizes/ offsets.
Old Feb 16, 2005 | 08:56 PM
04RioS2k's Avatar
The front is 18x8 and the rear is 18x9.5 but the offset isn't stated so hopefully Jim will chime in and let me know...because I did the wheel search with my04 as a guide and it showed that the professor would fit......
Old Feb 17, 2005 | 11:24 AM
Former Sponsor
They are 49mm offset front and 55 mm offset rear. Just stay with the 225/40R18 and 245/35R18 and you should be fine. Like I stated before you may have to run a little more negative camber with the car being lowered. Depending on the car and the tire you choose you might have to roll the fender lip as well. I have not had anyone tell me they had to roll the fenders yet.
dirttys2k
Nov 1, 2012 11:54 AM
114_ap2
Feb 21, 2008 01:47 PM
onejdmap1
Mar 24, 2006 04:45 PM
B SweepeR B6
Apr 1, 2005 06:56 PM
x46359
Apr 28, 2004 01:46 PM
