Will I rub?
Old Jun 30, 2005 | 06:50 AM
S2KrNBRuIn's Avatar
Default Will I rub?
My friend with a Silvia recently told me that he was gonna sell his Advan RG's and he was gonna give me a real good deal, but his offset is a little lower than what I know as the S2K's offset. Basically, I was wondering if there would be alot of problems trying to fit these rims on my car, and if it would ok.
Wheel Specs:
17 x 7.5 +43mm ---------> should be approximately +48mm
17 x 8.5 +37mm ---------> should be approximately +48mm
Thats not too large in difference since 10mm is only one centimeter but I would really appreciate it if someone could give me some professional advice because I really love the way these rims look.
Old Jun 30, 2005 | 08:01 AM
SIIK2NR's Avatar
The rears are way off..... sorry...
Old Jun 30, 2005 | 08:54 AM
JSR_AP2's Avatar
If you're not lowered, you should be ok, but keep in mind, the rear will stick out slightly. If you plan to lower your car, you'll rub often, even w/ high camber.
Old Jun 30, 2005 | 11:01 AM
S2KrNBRuIn's Avatar
Arrow
Thanks guys....its too bad because I really wanted the rims...
Old Jun 30, 2005 | 11:12 AM
JSR_AP2's Avatar
If your friend's willing to, maybe you can buy them from him, sell them to an s13/s14 owner for a bit of profit, and use that to get yourself a set of RG2s...just a thought, but check w/ u'r friend to make sure he doesn't wanna make the profit instead.
Old Jun 30, 2005 | 11:17 AM
Ubetit's Avatar
Your "should be's" are even off.
17 x 7.5 ---------> should be no less than +50mm with a 225 tire
17 x 8.5 ---------> should be no less than +55mm with a 255 tire
Old Jun 30, 2005 | 11:21 AM
S2KrNBRuIn's Avatar
ok...my bad, dont have to try to prove yourself to others.
Old Jun 30, 2005 | 01:19 PM
03_AP1's Avatar
won't fit - too bad, RG's are awsome rims.
tonydang25
Mar 23, 2009 03:46 PM
Veloxitymadog
Dec 10, 2008 01:59 PM
abv
Mar 15, 2006 09:44 AM
boyguan
Jan 10, 2006 11:49 AM
turb037
Mar 16, 2005 09:04 AM
