Will my tires fit?
Old May 7, 2013 | 06:17 AM
9000revolutions's Avatar
Default Will my tires fit?
So I searched around the net and have gotten mixed answers. I have a set of 255/35/18 tires. and an 18x8 wheel. I know its prefered to put this tire on a 9" wheel, but will the tire fit on an 8" wheel?
Old May 7, 2013 | 07:57 AM
1nate7's Avatar
It will be a little pinched, but physically will fit.
Old May 7, 2013 | 08:42 AM
Even being a 35 series tire? The search i did came up with the same answer but was for a 40 series.
Old May 7, 2013 | 09:10 AM
1nate7's Avatar
That won't make much difference and a 255/35/18 is the proper profile to keep stockish tire diameter. Auto-x guys stuck with stock wheels have run wider tires than that, it's a compromise but you can do it.
Old May 7, 2013 | 10:28 AM
s2000Junky's Avatar
The shorter sidewall helps because it will deflect a bit less, which is the biggest issue with too wide a tire for the rim, but it will still be pinched so expect less then optimum handling, certainly at the limit.
10" wide rim is the optimum width for a 255 fyi. 9" is the most popular because it’s the easiest to fit on the car. Not because it performs better.
sho-one
Sep 2, 2018 10:22 AM
liquidgsr
Mar 29, 2013 09:03 AM
114_ap2
Jun 4, 2008 06:00 PM
S2KB00ST
Jul 20, 2006 12:31 PM
Balance_Point
Jan 30, 2006 08:21 PM
