Will s2000 fitment 18" stagger also fit NSX?
I'm looking at a set of 18" stagger Advan rims but thinking these would also be nice to interchance with my s2000.
Just curious.....
I don't mind buying spacers for the NSX to get s2000 wheels to fit....
Assuming most s2k's run 18x8 up front? (same as nsx?) while the s2000 rears are 18x9.5?
Only thing I'm not sure of is offsets...
what do you think?
rick
Just curious.....
what do you think?
rick
here is some more "food for thought" because I have no problem buying spacers to make s2000 wheels fit an NSX.
Example: For my previous Work Meister s1r's the sizing was...
18x8, +56 up front running 225/40/18 tires
18x9.5, +63 in rear running 265/35/18 tires
According to an NSX prime member his fitment on his NSX is:
18x8, +42 up front running 225/35/18
18x10, + 36 in rear running 273/30/18
So 18x8 fronts, +56 (s2000) vs. +42 (nsx) is a diff. of 14mm
18x9.5 or 18x10 rears, +63 (s2000) vs. +36 (nsx) is a diff. of 17mm
Is this difference correctable with say a 15mm spacer up front and 20mm spacer in the rear approximately?
thanks
rick
thanks
rick
BioBanker
15
Apr 4, 2006 06:10 AM
