Will these wheels fit my +45mm & +75mm fenders?
Little more in the front and maybe a finger in the rear. This is really the only photo i have here at work for a visual. that is with -2.0 camber
Not super flush as i need it to function well for occasional track days and daily duties without running a ton of camber.
I believe your specs would fit under a widebody. With this kind of extensions (Circuit Garage I assume) you can go real wide. I would suggest to pay a visit to Fitment Industries website, there's a ton of S2000 to which you could compare, including a couple of widebodied ones. I guess it depends on how much camber you want to run.
https://www.fitmentindustries.com/wh...2000&sort=date
I encourage you to go wide fellow owner
