Will these wheels and tires fit?
Hi guys, I would like to know if a 17*9 wheel with a +62mm offset will fit on the rear with a 255 size tire. Also, will a 17*8 wheel with a 45mm offest fit on the front with a 225 size tire?
Thanks,
Alex
Thanks,
Alex
17x9 +62 will not rub with a 235/40-17. NO PROBLEM.
Whereas with 17x8 +45, you'll be closer to rubbing even with a 215.
IMO, 17x9 +62 is a MUCH BETTER OPTION for fronts than 17x8 +45.
Capisce?!
