will this work?
Old Nov 29, 2002 | 11:13 PM
qwksir's Avatar
Default will this work?
i was won'dering if any can tell me if these rim sizes fit the s2000.....F - 17's and R - 18's assuming the offsets are correct?.....
Old Nov 29, 2002 | 11:32 PM
Schatten's Avatar
offsets and width will matter. are these from an nsx? or what other car?
Old Nov 29, 2002 | 11:34 PM
qwksir's Avatar
yes they are from an nsx......but assuming that the offsets and width are correct ...will it work
Old Nov 29, 2002 | 11:43 PM
Schatten's Avatar
I know there is one member out there that has them. I'm guessing these are factory wheels from a 97+, right? or aftermarket wheels? if aftermarket sizes/offsets will matter greatly.
otherwise, check out what the search engine came up with.
http://search.s2ki.com/search.php?q=nsx+wheels+fit
Old Nov 29, 2002 | 11:47 PM
qwksir's Avatar
[QUOTE]Originally posted by Schatten
[B]I know there is one member out there that has them.
Old Nov 29, 2002 | 11:52 PM
dave22's Avatar
17x7 OZ Superleggera with 225/45/17 Dunlop FM901 front
18x9 OZ Superleggera with 265/35/18 Dunlop FM901 rear
(sorry not sure about the offsets)
Lowered 1.25 inches with HKS springs
*very* little rubbing in the front and only in extreme situations. (it sits a little lower in the front now that the springs have settled)
NO rubbing in the rear whatsoever. This is strange because before I put the springs on I had BFG TA/KD and I got significant rubbing in the rear over moderate bumps. The Dunlops have a rounder shoulder and look slightly narrower than the BFGs did so I guess that could make the difference. If you go with 255/35/18s in the rear you should be fine.
Old Nov 29, 2002 | 11:54 PM
qwksir's Avatar
thanks dave22...that helped alot...
Old Nov 29, 2002 | 11:58 PM
dave22's Avatar
Sorry. I missed the whole NSX thing while i was posting. So I guess my last post was pretty useless. Anyway, I remember a while back there was a post called "Hi I post from Japan" or something like that. There were pics of a black S with gunmetal NSX wheels. I think it also had Neuspeed springs (1.5 inches?) It looked pretty mean and apparently they fit.
Old Nov 30, 2002 | 12:19 AM
qwksir's Avatar
dave22...actually your post helped out....they are aftermarket rims off a nsx so their not the oem nsx rims....so thanks again
Johnny 5
Nov 12, 2009 11:52 PM
STAIN
Feb 14, 2008 11:28 AM
CaymanS2k
Jan 17, 2007 05:02 AM
Sen
Feb 21, 2004 12:58 PM
