will this work on s2000 ?
Old May 11, 2009 | 09:58 AM
bradshit's Avatar
Default will this work on s2000 ?
Front 18*7,5 offset. 52mm
Rear 18*8,5 offset. 47mm
with 235'40 front and 265*35 rear Tires
will that work , with out hitting ?
enny body on that setup ?
Old May 11, 2009 | 01:57 PM
Mar48's Avatar
I think that should work although the recommended sizes would be 225/40 in the front and 255/35 in the rear
Old May 11, 2009 | 03:21 PM
Vik2000's Avatar
Should work, but I think you'll need a roll due to tire sizes.
Old May 11, 2009 | 03:23 PM
jaeyon00's Avatar
not only will you need to roll the guards, if you are lowered you will need to trim your bumper (and a fair bit of it at that!).
id go with thinner tyres, unless you really need the traction (which i doubt is the case)
UR_UP
Jan 22, 2009 05:57 AM
Mar48
Oct 14, 2008 07:04 AM
IIGQ4U
Mar 31, 2006 07:01 AM
LUV2REV
Aug 29, 2005 04:53 PM
dbox
Mar 25, 2003 12:59 PM
