Winter tires on MY05 S2000
Old Nov 8, 2007 | 11:20 AM
marcortega's Avatar
Default Winter tires on MY05 S2000
Hi,
Just wanted to know if you have any recommandation for winter tires (to be mounted on the stock 17" MYO5 wheels).
Do you use the same size as the summer tires (front : 215/45, rear : 245/40), or is it possible to put smaller tires without changing the geometry ?
Thanks for your precious advices.
Old Nov 14, 2007 | 12:41 AM
marcortega's Avatar
anyone ?
Old Nov 14, 2007 | 07:20 AM
Jim@tirerack's Avatar
Former Sponsor
You would want to run the OE tire size for the winter tires.
Old Nov 14, 2007 | 10:44 AM
TubeDriver's Avatar
I run 225/45-17 and 255/40-17 Yokahama Advan S.4.
Old Nov 15, 2007 | 05:22 PM
alSpeed2k's Avatar
I went with 16" Dunlops with rims from Jim on my 07. I've seen V rated 17" Hankooks at Discount Tire, but they are not available everywhere.
I don't know if Jim ships to Lausanne, but look here for a picture of the 16's on my S.
My Silverstone 07
al
Old Nov 16, 2007 | 12:48 AM
brimstone's Avatar
should be fine.
any major winter tire manufacturer is okay (bridgestone blizzaks, dunlop wintersports, etc)
Old Nov 16, 2007 | 02:34 AM
Luckyaze's Avatar
try a set of sumitomo, they are very quiet and not stiff.
Old Nov 16, 2007 | 07:43 AM
philbert's Avatar
I'm going to run 205/50 and 225/45 Yokohama AVS Winter, but on aftermarket wheels, whose offsets prevent me from running much wider. There is a conventional thinking to run slightly narrower tires in the winter, as this improves snow traction.
Old Nov 18, 2007 | 12:06 PM
marcortega's Avatar
I finally will mount Bridgestone Blizzack LM22 and LM25. It's apparently a good rated tire..
Cheers
sillyboybmxer
Dec 4, 2011 10:46 AM
Zed03
Jun 22, 2010 01:41 PM
digsetcrush
Jan 4, 2010 01:02 PM
stillmelloq
21
Dec 17, 2008 11:59 AM
S2K 4 ME
Dec 27, 2005 07:39 AM
