Work Centercaps falling off?
Old Apr 1, 2011 | 11:25 AM
JS2k.com's Avatar
Sponsor
Smile Work Centercaps falling off?
So I bought a brand new set of centercaps for 18" VS-XXs.
I put them on and about a week later one fell off, the front passenger. After that happened, I pushed on them hard to make sure the others were firmly in the wheel. Today, I notice another one missing!
Am I doing something wrong? There goes $60 down the drain.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Apr 1, 2011 | 02:40 PM
Keatre's Avatar
I assume you're putting the ring in as well, right? The only reason I ask is my brother did that once, bought center caps and just pushed them in. He had no idea about the ring installed on the back. If you are, maybe check and see how the other rings are lining up?
Old Apr 2, 2011 | 02:41 PM
sebringsilvers2000's Avatar
yeah i agree its got to be the rings. i had one fall of my VS's and after talking to Logan at Work, we discovered that the previous owner put the rings on the outside of the snaps instead of the inside (the ring should be expanding the snaps as opposed to contracting them). Also, im sure this isnt the case for you since you got yours new, but there are two different sizes of center caps, one has the snaps on the edge of the cap and one has the snaps set in a little more, make sure you get the right ones!
Old Apr 7, 2011 | 05:44 PM
JS2k.com's Avatar
Sponsor
Hmm, I didn't even see a ring. I just opened it and put em on the wheel. I guess I'll have to take the wheels and caps off to see exactly what is going on.
__________________
_________
Old Apr 19, 2011 | 09:12 AM
JS2k.com's Avatar
Sponsor
I bought them brand new, and here's a pic of the two remaining ones. The ring is on the inside.
Interestingly enough one fell off from the front wheels, and one from the rear. When I went to remove the two remaining ones, the rears came off using just my fingernail, and the fronts required a bit more effort.
I saw on the website that the centercaps were supposed to fit all 18" VS-XXs.
Wheel specs: VS-XX 18x8+33 19x9+38
__________________
_________
Jacksparrow
Jul 25, 2011 09:49 PM
01spaS2K
Mar 28, 2007 10:20 AM
kent-k
May 3, 2006 12:46 PM
nsxinsac
Dec 11, 2005 02:19 AM
herrsonic
Mar 18, 2005 03:26 PM
