work s2r size and offset
Old May 8, 2004 | 09:35 AM
v2000's Avatar
Default work s2r size and offset
I'm planning on buying the s2r and am trying to find the right sizes, i've heard from some to go with 18x7.5F and 18x8.5R or 18x8F and 18x9R. So which one of these are the right fitment?
Old May 8, 2004 | 12:12 PM
HarleyMB41's Avatar
You can go 18 X 9" in the rear with a +63 and a 18 X 8" in the front with a +51 offset. That what my Meister S2R's are.
The offset for our car is actually the most significant number--more so that just rim width etc..
Also, remember that different tire manufacturers have different "footprints" , or contact patches, meaning that a Dunlop (for example) with a relatively small tread contact patch may need a 265-35 X 18" in for a 9" rear wheel, but a Bridgestone S02 may only need a 245-40 X18" for the same wheel, so that is also important as far as knowing what tire is applicable....
Hope that helps.
HMB
Old May 8, 2004 | 06:05 PM
davidb's Avatar
The 63 offset rubbed on my car with Porsche spec S02s - 10.2" wide tire.
And that was after I had modified the fender liner attachement point with a dremel and a hammer.
Stock height
Old May 9, 2004 | 03:36 AM
v2000's Avatar
ok, will the 18x8 and 18x9 fit with coilovers or there isn't a problem at all?
thanks for you help
lexar13
Dec 7, 2008 11:45 AM
wannabuy
Jan 22, 2006 12:09 PM
yellafeva
Aug 14, 2004 12:04 AM
Mutlu
Mar 15, 2004 02:00 PM
Casas
Jul 8, 2003 06:19 PM
