Need to know ASAP ! S200 HUB BORE SIZES!
Hi there, what sizes do i need to get my wheels machined to fit the s2000 hub bore size? ive seen
70 70.1 70.3 70.7
what is the official sizes?
70 70.1 70.3 70.7
Ok so this is for whoever searchers this same question and reads this thread
- I am 100000000% certain it is 70.1 MM
I had them machined today and it fits perfect.
yes- bigger affects the load bearing capacity of the rim as well as the stability of it ( vibrations etc )
this is why hubcentric rings exist to make the rim run concentric to the hub. The closer to the hub size it is the better the rim will peform
so the offficial word is 70.1 MM
i just ordered a set of wheels that use a 73mm bore. i was gonna order hub centric rings. i did some research and found out my rpf1s are 73mm as well im not running any rings and the car is fine with no virbrations. so i guess ill be okay
