NOTICE: Correct Rear Tire Size AP1
#121
Former Sponsor
The difference is only less than 1/3". It is the best size to go with other than the OE tire. You can't tell the difference in the height.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Thank you
#122
if someone goes with a 245 in the rear for a non OEM tire (245/45/16) does the tire stick out anymore than the original 225's?
reason im asking is my car is very low and I dont want to have rubbing problems. I need to make sure the tire will fit inside the wheelwell with no problems. I have the stock rims by the way
thanks
thanks
#126
Originally posted by schwett
this is a 17" BFG G-Force KD 245/40/17, compared to the stock tire. somewhat wider but no more rubber on the road. the stock tire has very square shoulders.
The OEM SO-2 rears have extra wide tread width, and very small/few grooves.
Thanks for posting that!
Ted
#127
A quote from the original post:
"If you are not running the OEM tires on the rear of the S2K, you should be running a 245/45/16 in the rear."
If you are supposed to use 245/45/16's on the rear, why does the tire rack recommend 225/50/16's regardless of the make or type of tire? Confusing.
Also, the rack lists two choices for the SO-2's, the Honda EOM and the Porsche OEM at about the same price. rating on the Honda oem's is WR- on the Porsche's it is ZR.
Are there compelling reasons to choose one over the other?
Thanks
Thanks
