Wheel choice (expert needed)
Old 01-17-2005, 04:47 AM
LemonS2k's Avatar
Default Wheel choice (expert needed)
I am getting the ASM +25mm front and rear fender.
planning to run 275 in the rear.... 235 in the front
which width of wheel for 17" would be the best?
and most importantly ... what's the offset for the wheel ( with the +25mm fenders) ?
Thanks in advance
Old 01-17-2005, 11:09 AM
Batbite's Avatar
You don't need to buy fender flares to run 275's in the rear..................just wheels with the right / correct offset...........
Not so sure about the 235's for the front.....? Why this size...?
I would ask you what your goal is?
A. put fender flares on the "S" because you like the look.....or....
B. you just want to run wider tires.........
Understanding what you are trying to accomplish will be a factor in what wheel / tire / offset you should choose.
Old 01-17-2005, 12:58 PM
LemonS2k's Avatar
ASM did the fenders to their car... only with 245 all around... I want to do the same thing... except i want to keep the staggered set-up.. therefore the 275 rear 235 front..
probably, put on the Toyo RA-1s.. and 235 is the only size they come in for 17" that's in that range...
My goal is for the look, yet still want the best performance out of it...
just want to know what's the right size of wheel and offset i should go, with the extra 25mm ..
Old 01-17-2005, 01:43 PM
Batbite's Avatar
If you're set on 235 front & 275 rear
The correct wheel widths would be:
8.5" - front
10" - rear
As far as offsets go.........you'ld have to do the math.......but here is an educated guess
25.4 mm = 1"..............your fender flares are 25 mm...........so do the deductions from that.
8.5"..........with correct fitment for the front would have approx +56 / +57 offset without the fender flares...........so -25 mm or so to account for the flares..........+33 to +37 might be a safe bet
10" in the rear with correct fitment (no fender flares) would be a +75..............so deducting 25 mm or so would approx +50 to +54 or so.
Just a guess.............but as I mentioned above you can run wider tires without the flares
I'm lowered 1" and running:
225/40/18 in the front - no fender flares needed.........+51 on a 8.0" wheel.
285/30/18 in the rear - no fender flares needed...........+76 on a 10" wheel.
Old 01-17-2005, 11:01 PM
LemonS2k's Avatar
wow... that's a very aggressive offset... you are not having any rubbing issue with this setup?
Mijae007
05-03-2017 11:04 AM
revoluzion9k
01-20-2016 12:49 PM
csw
09-08-2012 04:26 PM
CarbonS2000
10-20-2011 06:36 PM
starbai
02-11-2010 03:18 PM
Quick Reply: Wheel choice (expert needed)
