to Pete aka ruexp67
FYI: There are (currently) NO right hand OEM C6 Z06 rotors
ALL C6 Z06 rotors are left handed. Those mounted on the right have a "LEFT" stamped indicator.
Therefore, those installed on the right have the cooling vanes reversed.
Not really a signiificant issue for street cars; but may cause reduced cooling (at least on the right) on tracked cars.
The 2 available Part #'s are for left hand rotors only F/R, so you can not even order right hand rotors, if any really exsist.
Aftermarket should have a solution soon.
However, tracked stock classes may be screwed.
That's some funny shiznit.
For all practical purposes, I would be through the stock rotors pretty damn quick anyway. I put all new rotors on my car at 3,100mi on the odo. I did not get the rotors from GM, they are technically aftermarket.
The above is pretty damn funny, but it wouldn't bother me much.
Not the same as mine. Those are the C6Z06 rotors which are cross-drilled from the factory. They are specific to the C6Z06 and would be a 2006+ part only.
I am not sure of the rotors are different from a C6 coupe/vert to my car though. I know the Z51 option comes with cross-drilled rotors too, so those are definatly different.
Check the 2005 'vette vs. the 2004 'vette.
