S2000 Body and Paint Body kits, paint, ding repair and related discussions
APR GT3 Mirror Install
Old Apr 4, 2013 | 09:30 PM
KoketsuCivicSi's Avatar
Default APR GT3 Mirror Install
My wife bought me some mirrors for the S2K, so I decided to do a step-by-step install for you guys. I know there's another install page, but I used a slightly different method for the install.
The mounting hardware came pre-mounted, making this process a lot easier.
Remove #1 from #2 with the supplied allen key. Attach #2 to #3, then screw #1 back to #2 to connect everything together.
Here's what it should look like.
Three philips screws and one snap-in bolt attached to the door panel will need to be removed. The window should also be rolled down.
The power control module should pop right off, then remove the power window and mirror harnesses.
I learned the hard way that the handle on the door panel cannot be removed and is not necessary for door panel removal. Posted the pic for reference anyway.
Pop #1 off, #2 comes out with a 12 socket, #3 (4) is philips that hold the speaker in. Remove the speaker and disconnect the harness.
#2 from the previous pic.
#1 from the previous pic with (2) 10 socket behind it.
Remove the two 10 socket.
Disconnect the harness for the power mirror.
Harness should slide right off the the clip.
I went ahead and removed the molding that sandwiches the window for ease of access. It should snap right off, but use caution.
I then removed this piece that keeps the window on its track. Once again for ease of access to the bolts holding the mirror.
(3) 10 socket attaches the mirror to the door.
An extension reaches it through a hole in the door frame.
Mirror removed.
Installed.
Old Apr 4, 2013 | 09:51 PM
realblag's Avatar
Nice write up. You left out the part about trying not getting that white/tan sealant from the moisture barrier on everthing.
Old Mar 25, 2014 | 04:37 PM
josserman's Avatar
having trouble getting mine to lock in place. Anyone else?
Old Mar 25, 2014 | 05:59 PM
alphalanos's Avatar
what do you mean. mine sometimes come loose and i have to tighten the top bolt on the mirror.
Old Dec 18, 2016 | 05:11 PM
GPW_LOVE_012's Avatar
Do the mirrors eliminate the driving side blind spot?
KatchMe808
Jan 28, 2012 06:36 AM
prodriverex
Mar 2, 2008 05:16 AM
jdmbm
Feb 29, 2008 01:57 PM
DoubleOh2000
Nov 9, 2006 02:48 PM
north9586
Oct 16, 2004 12:14 PM
