petawabit's turbo AP2
Old Jun 19, 2013 | 08:40 PM
petawabit's Avatar
Default petawabit's turbo AP2
long time lurker who has mostly absorbed what s2ki.com has to offer and after a long year or two or three, am finally making a thread to highlight my build and also answer any questions people may have when going turbo on their s2000s (I know I've learned a lot, especially from all the little quirks of building and maintaining this car).
Thanks to s2ki and the sub-section that I call home, forced induction Ryan and Ron over at Rising star motors for all of the help with general installation, Sheldon and Adam at S-tech motorsports for the build and assembly of the motor, LJ and Justin at fullblown motorsports, Jason at Jason Noren fabrication, Mike at ATP wrap, and various members of this forum: nsxtasi (si), a long time friend who is actually the first person I met from this forum who I still hang out from time to time today, scorpionT for all the guidance, patience with all my questions. wadzii, sarek (paul), vtecs2k (pierre), Fred from vis(gunshow),Shane and Mike over at Autowave for the tune and help along the way, and many other on this forum for their inspiration to this build. My Apologies for those who i've forgotten.
Specs on the car:
05 S2000, originally silverstone, repainted moonrock
436whp at 15psi. 91 octane, dynodynamics at autowave in huntington beach, ca
Exterior
-VIS mugen FRP hardtop with rear glass window-painted moonrock
-Shine ASM front bumper with ASM replica front carbon lip
-downforce front 30mm fenders
-Shine side diffuers
-Gladman fabrication rear diffuser (previously had spoon rear diffuser)
-Voltex type 4 dry carbon wing
-Seibon wet carbon trunk
-Retro solutions 55w HID Kit
-18x8 +48 with 25mm spacer, 18x9 +55 OZ ultraleggeras with 225/275 bridgestone tires (temporary)
-Stoptech front big brake kit, 328x28 slotted, red
Interior
-UK Ap2 cluster with Qube engineering interior LED kit, white
-Recaro Spg x 2, buddy club rail driver, bride fg rail passenger
-worksbell hub, Splash quick release, momo tuner 280mm wheel (used to have momo monte carlo 330mm, regret selling it). Splash steering wheel lock
-06 rollhoop with modifry upgraded speakers
-Carbon fiber and aluminum battery mount on spare tire, Deka ETX14
-honda access floor mats, black
-alpine head unit with modifry harness
-modifry dash bracket with i-bolt holder for note 2 phone (thanks IdashX!)
-Honda FD2 shift knob
-AEM Serial gauge
-Alloy craft hard top locks
Suspension
-Tein SRC (previously had kw v3's)
-J's racing front and rear roll center adjusters
-Saner front sway bar
-20mm front bumpersteer kit
-AP1 steering rack with L-Con motorsports solid steering rack mounts
-CR steering rack stiffeners
-Whiteline front under brace
-Gladman fabrication front shock tower bar (previously had asm front gt bar)
-ASM floor bars
-ASM GT rear shock tower bar
-(previously had rear lower beatrush reinforcement bar)
Drivetrain
-Innovative transmission mount (75a), previously had 85a and 60a durometers
-Science of speed billet carbon twin plate
-Stock transmission
-Stock rear diff
Engine
-F20C, 9:1, 87mm darton sleeved, pauter rods, CP pistons
-CNC ported heads, welded combustion chamber, supertech valvetrain, .50mm oversized intake and exhaust valves
-Full blown motorsports divided exhaust manifold, gt35r 1.06 exhaust, downpipe, and dumptubes. Inconel heat shields for manifold, turbo, and downpipe by www.atpwrap.com
-OEM headgasket
-AP1 cams
-AEM EMS series 2, tuned by Mike at autowave
-precision 46mm wastegates x 2
-Mac boost solenoid
-Innovative engine mounts, 75a
-ptuning oil distribution block
-Sound performance boost activated exhaust cutout
-magnaflow 3" high flow cat
-asura 3" dual, catback exhaust (previously had 60mm amuse dual, berk dual 60mm)
-ATI crankshaft pulley
-Toda timing chain
-Inline pro TCT
-ID 1000cc injectors
-340lph fuel pump
-Full race intercooler piping and core
-Tial 50mm bov
-Stinger 150amp circuit breaker for battery relocation kit
-SOS 3 bar map sensor
-AEM o2 wideband, AEM oil pressure gauge
-Full blown motorsports radiator and slim fans
-AB Speed coolant reservoir and oil catch can
-NGK range 8 spark plugs
-RSX coil packs
-Oil filter relocation kit
-Brad penn 10-40w synthetic blend oil
Random photo with the daily in the background:
gt35r and borg warner s300sx, which didn't clear the hood
wrapped downpipe, midpipe with SP performance cutout and high flow cat:
off the car:
head ports:
dyno graph, mike was commenting how the motor seemed a little lazy and it shows in the dyno graph. He's thinking it may be the modified head, tuned to 15psi on a safe tune with 91 octane. will retune after i replace the broken knock sensor and get all the bugs worked out:
petawabit's Avatar
comparison of silverstone to moonrock
lots of these types of photos
thanks Ptuning for lending me the oil distribution block to see if it clears my setup!
wrapped dumptubes with dei titanium
battery in back. had to redo the grounds as it would stall while decelerating
various progressive engine bay shots:
most recent engine bay shots:
Thanks for looking!
Old Jun 19, 2013 | 08:46 PM
petawabit's Avatar
i'll redo the links from dropbox shortly. that took longer than i expected
Old Jun 19, 2013 | 08:57 PM
indi00's Avatar
Not that laggy for a GT35.
I use tinypic.com
Old Jun 20, 2013 | 07:48 PM
Irishflame27's Avatar
looks awesome man, loving it!
Old Jun 20, 2013 | 10:59 PM
03supers2k's Avatar
Awesome. I hope you figure out the engine, and the knock sensor. Your local, and close to me, I'm surprised we haven't met. Lets meet up one day, I'd love to check out your car in person Good luck man, I hope you figure everything out.
Old Jun 21, 2013 | 05:26 AM
passmans2kny's Avatar
sweet build good luck on the retune
Old Jun 21, 2013 | 08:14 AM
herecomesboost's Avatar
Nice build. How much would you have had to cut in order to fit the s300sx? I have an s366 on the way (same manifold). To clarify, I'll cut whatever gets in my way lol. I'm just curious.
Old Jun 21, 2013 | 08:18 AM
baZurk's Avatar
Kyle, looks like you will have two dumptubes and and turbo sticking out of your hood
Old Jun 21, 2013 | 08:22 AM
Ha! So much for sleeper status. I'm seriously considering running an uppipe setup again as well.
