Izze air pump delete install
Hi all. I installed the izze air pump delete kit today and my CEL came on (wasn't on before). I live in Rowland Heights...anyone local have any experience with this mod?
P.S. I had no issues with air pump before, just trying to cut some weight and clean up engine bay.
Recheck your connections. Solder not wire nuts. Read the code and make sure it's not for something else like a gas cap.
I also would recommend against the clip-on tap things. I had issues after trying to use them on my kit. I tried to wiggle them and dig the connectors into the wires to make sure the connectors were making contact with the wires, but I couldn't get them to work. I ended up removing them and splicing like I should have and using heat shrink wrap on them.
