Sponsored by: CARiD
Izze air pump delete install
Old Jan 11, 2014 | 04:54 PM
eparra83's Avatar
Default Izze air pump delete install
Hi all. I installed the izze air pump delete kit today and my CEL came on (wasn't on before). I live in Rowland Heights...anyone local have any experience with this mod?
P.S. I had no issues with air pump before, just trying to cut some weight and clean up engine bay.
Old Jan 11, 2014 | 05:07 PM
freq's Avatar
Recheck your connections. Solder not wire nuts. Read the code and make sure it's not for something else like a gas cap.
Old Jan 11, 2014 | 05:46 PM
eparra83's Avatar
I will recheck in the morning. I dont have a saucer gun, I was using the press on connecters that came with the kit.
Old Jan 11, 2014 | 05:51 PM
freq's Avatar
Those half taps as they're called do work most of the time. Again, good luck and I'm sure it's just something simple.
Old Jan 11, 2014 | 06:08 PM
Suzuka_Joe's Avatar
i installed the kit. worked great. check your connections
Old Jan 11, 2014 | 06:43 PM
eparra83's Avatar
Thanks guys. I'll get some new half taps and redo the connections in the morning.
Old Jan 11, 2014 | 07:17 PM
Polaris0352's Avatar
Seriously, you can get a solder gun really cheap and it would work forever instead of for a while with half taps... You're asking for problems.
Old Jan 11, 2014 | 07:23 PM
S~Factor's Avatar
Yeap, re-check wiring and don't forget to disconnect the negative battery cable beforehand.
Old Jan 12, 2014 | 12:25 PM
gptoyz's Avatar
solder & shrink wrap, don't use taps!
after that test the connection
Old Jan 12, 2014 | 03:39 PM
CoolGuy094's Avatar
I also would recommend against the clip-on tap things. I had issues after trying to use them on my kit. I tried to wiggle them and dig the connectors into the wires to make sure the connectors were making contact with the wires, but I couldn't get them to work. I ended up removing them and splicing like I should have and using heat shrink wrap on them.
