Mark this thread as Unsold
ChallengeUSA 76TA-S, Berk HFC
I've got a ChallengeUSA 76TA-S 3 inch single exit exhaust system for sale...with a added on pipe to try and help with drone,I used a diffuser so alot of the pipe was hidden anyway.
The drone is perfectly fine under 3krpm at a constant speed, but as with majority of systems there is alot of drone at 3-4krp.
I used a diffuser so a lot of the pipe was hidden anyway.
Made 228bhp with Romain at Eurospec, with intake, manifold and HFC, Romain said he usually gets them numbers with a decat.. so this system is good if you're looking for a high powered n/a or turbo build.
Could do with a more thorough clean up as can be seen and needs new gaskets/bolts
Looking for £500ono Paid £750 last year from a member off here. Collection only Essex/Chelmsford.
Heres hows the exhaust looks on the car, this was before the add on pipe which you'd barely be able to see.
Heres a pic before I removed it without the diffuser:
Also have a Berk 70mm hfc with a boss welded on suitable to AFR sensor £80 delivered only used for approx 6000miles can sort out a bung for the extra boss if needed.
The hfc is provisionally sold to dls91 at the moment, just waiting for him to get back to me.
