S2000 mechanics in NYS
Old 05-09-2016, 08:40 AM
FuzzyRuttin's Avatar
Default S2000 mechanics in NYS
The S won't be on the road for a while. I'm following the first piece of advice and cross posting in this forum:
https://www.s2ki.com/s2000/topic/115...#entry23960560
Perhaps new engine block. Not sure yet which way to go.
Old 05-09-2016, 01:41 PM
Car Analogy's Avatar
Received 1,320 Likes on 998 Posts
That...doesnt look good. I think you are toast there. That cylinder appears to be too far gone for our frm coating.
I concur with advice to look for used motor.
You set out to make your motor more reliable by modifying, and ended up costing your motor. You were brave enough to post your mistake, for the benefit of others. Good man. Lesson for all to learn, be careful the actions you take to avoid something do not more quickly lead you to it. This is especially true when modifying your car to 'protect' it.
Sent from my SM-G920P using IB AutoGroup
Old 05-09-2016, 03:38 PM
Slowcrash_101's Avatar
Non of your bores were measured correctly, either that or that block is warped. I'd just assume it's trashed, and get another engine.
Old 05-09-2016, 04:06 PM
windhund116's Avatar
Received 1,437 Likes on 964 Posts
Hope your head isn't warped, too. Cams spin free in head, with rocker arms removed?
Old 06-05-2016, 06:48 AM
What should measurements look like? It seems reasonable to have more wear at the top and bottom of the cylinders. Based on what you said, I took a couple more measurement runs, about a week apart, without having old data in front of me to avoid any judgement bias:
I don't have a good way to measure block flatness without buying a $100 precision flat edge. I would like to know if it really is warped though, just for my own peace of mind. Haven't pressed the buy button.
Old 06-05-2016, 06:51 AM
Yes, cams freely rotate. End play measures about .003"-.004" on each. According to the shop manual, new measure .002"-.006", and service limit is .012".
Old 06-05-2016, 04:28 PM
The minimum factory bore is 3.4256" All your bores are significantly below that.
Old 06-07-2016, 03:43 AM
Ah, light bulb. I'm borrowing my buddy's bore gauge, and assumed it was accurate. What is suppose to be 3.450" cals out to 3.4610" with a high precision micrometer. I didn't retake the measurements, just punched in the right number.
Old 06-07-2016, 05:43 AM
Not looking good, at the very least you'll need to do the whole block with oversize pistons. From what I can tell they're on backorder. You'll have less headaches cost and downtime by getting another running engine.
Oversize limit is 3.4354" after that you're better off sleeving the block.
Old 06-07-2016, 03:21 PM
Since the engine gets pulled for boring, I am inclined to agree with everyone and just get another block. How much work would it be to buy a (new?) bare short block and transfer everything over? Time is not really an issue at this point. There are a few online parts suppliers that sell bare blocks, not sure if they are refurbs or brand new, going for about $1800. Short blocks with oil pan, crank, pistons, rods, etc. seem to go for around $3500. Price on used long blocks widely varies, cheapest I saw was $3500. These numbers seem about right?
Quick Reply: S2000 mechanics in NYS
