rca length? is 9ft enough
Old Jul 28, 2006 | 08:49 AM
SuzukaS's Avatar
Default rca length? is 9ft enough
I purchased all of my audio setup before even taking possesion of my S and i remembered the car being much shorter so i bought a set of 9ft rca's for my 4 channel amp. Now that i have it, im wondering if it is going to be long enough. If it will work, can you run it on the side as usual, or do you have to run them up the middle. Also if 9ft is not enough, would 12ft work. The installers in my area have never worked on one, and think 9ft will work, but i just want an owners word before tearing my car apart. Thanks in advance.
Thought i would update this for anyone in the future who does a search. 9ft will work. You must go up the middle, and decide which side of the trunk u want the amp on and run on that side of the center console as they work, but arent too long once in the trunk area.
Old Jul 28, 2006 | 09:20 AM
oth's Avatar
oth
it depends partly on how you run your RCAs, and where you mount
your amp. I have 4-meter (13 ft) ones run through the center console to
my amp located over the gas tank, and I think 9 ft would have been ok,
but if you're running down the side and into the tool well, you'd need
more. I'll let someone who has done it that way answer exactly how
much more, though.
Old Jul 28, 2006 | 09:30 AM
SuzukaS's Avatar
i would like to put my amp in the trunk on the passenger side, standing up if that helps. i would prefer to run the wire on the side, but if i have to run up the middle that is fine. if i have to get different wire, ill just get long enough to run it on the side.
Old Jul 28, 2006 | 09:57 AM
JDM S2000's Avatar
Banned
that is plenty, i have the 12 footer and can hang it over my rear bumper
Old Jul 28, 2006 | 10:06 AM
NFRs2000NYC's Avatar
Again, depends on how you are going to wire it. I can bet 9 ft isnt enough, and if it is, it will be tight at hell. 12ft is enough if you run them down the center console.
Old Jul 28, 2006 | 10:30 AM
JDM S2000's Avatar
Banned
I should have mentioned i ran mine down the center console
Old Jul 28, 2006 | 11:02 AM
SuzukaS's Avatar
thanks for the replys. anyone actually run 9 here?
Old Jul 28, 2006 | 11:13 AM
Cubs2k's Avatar
Down the center only.
Old Jul 28, 2006 | 11:43 AM
darkknight1999's Avatar
9 footers only work on down the center, if you run them down the sides then you need to use 15 </> footers so you have some nice working room. You might be able to use 12's but it will be tight.
Old Jul 28, 2006 | 01:22 PM
SuzukaS's Avatar
ill probably just stick with the 9ft then. i really like the ones i have. its the Stinger 4 channel set that is all in one cable (if that makes any sence). and ive used them before, and have had great sound quality out of them. thanks for all the advice.
jlvtx1800
Apr 23, 2004 04:12 PM
145
Jun 29, 2002 08:01 AM
ricklobo
Mar 11, 2002 08:31 AM
blowns2000
Apr 20, 2001 06:55 AM
deadpedal
Jan 18, 2001 08:24 AM
