Which wires can run along the console?
Old Jun 28, 2002 | 12:38 PM
145's Avatar
145
Default Which wires can run along the console?
Considering the amount of heat around the console area, are there certain wires that shouldn't be run there? The wires that I'll need to run eventually are: turn-on lead for amp, RCA from head to amp, power to amp, speaker wires from amp to doors. Which of these, if any, would be OK along the console?
thanks,
gil
Old Jun 28, 2002 | 04:26 PM
MacGyver's Avatar
If the heat ever gets hot enough to burn the insulation off of a wire, watch out, because your carpet is about to burst into flames! Generally I try to stay away from the center console due to the high noise environment created by spinning metal inside, but if I had to choose, I'd say power would be the least problematic. Send the RCAs down the sides of the car (under the door sills)...same with the speaker wires.
Old Jun 29, 2002 | 06:19 AM
lucid's Avatar
RCAs, speaker wire and remote on (oppositie signal wires) are fine down the center console. Run the power from the battery along the right side of the car (if you running bigger than 8 gauge its too thick to run down the center).
Old Jun 29, 2002 | 07:29 AM
mas's Avatar
mas
You can run all wires, no problems. Just not the power, if you could avoid it. There is actually a heat shield there under the console leather, just make sure the wires are above the shield and not under it.
Old Jun 29, 2002 | 08:01 AM
lucid's Avatar
I run one set of RCAs down the right side of mine for the Sub amp its a 6ft wire. Other side has the remote on power. Its best to keep the RCAs as short as possible.
plutonium239
Nov 1, 2007 09:24 AM
dmw16
May 6, 2007 09:50 AM
all-trick'd-out
May 4, 2004 12:57 PM
ruexp67
Jun 2, 2003 06:14 AM
Squeezer
May 15, 2001 06:41 PM
