★☆ 2004 Spoon S2000 Coupe ☆★
Old 12-13-2007, 12:39 PM
AlexS2200's Avatar
Location: 13851 A Better Way #11D, Garden Grove, CA 92843
Default ★☆ 2004 Spoon S2000 Coupe ☆★
I began this project in April 2006 when I purchased this car. The car was a 2004 Berlina Black and only had 8000 miles on it. The car was completely stock and was an unpainted canvas. Now the car is complete and has been upgraded visually / aerodynamically and mechanically. My main focus on this car is to build a street car that could be competitive on the track but also keep its functionality for street / track driving use. Basically I wanted to build a car the way Shelby would build a Mustang or AMG to Mercedes. I hope this car is appealing to a variety of people of all different age groups and thanks for reading.
Ichi San (CEO Spoon Sports) & I
Willow Springs TT - Big Track
Modification Specs
Power Unit
Spoon Oil Filler Cap
Spoon Magnetic Drain Plug
Spoon spark plugs
Spoon Carbon - Kevlar Plug Cover
Spoon Baffled Oil Pan
Spoon Oil Catch Can
Spoon Alternator/Serpentine AC bypass Belt
Spoon Radiator Hoses
Spoon Radiator Cap
Spoon Thermo Switch
Spoon Thermostat
Spoon Radiator Stays
Spoon Small 12lb Battery
Spoon Small Battery Stay Set
Toda Adjustable Cam Pulleys
Skunk2 Valve Springs
Skunk2 Titanium Retainers
Skunk2 Valve Spring Bases
Aluminum 5 piece pulley kit
AEM EMS 1052
AEM UGEO Wideband Controller
Modifry ECT Module for AEM EMS
Hondata Heat Shield Gasket
Motul 100% Syn Engine Oil 300V Chrono 10W-40
L★Con Elongated Valve Cover
Intake & Exhaust
Spoon Air Cleaner/Filter
Spoon Carbon Kevlar Engine Fresh Air Duct
Spoon Thermo Wrapped Air Box
Spoon Venturi Throttle Body
L★Con 4-1 equal length 888 Header w/ Megaphone
L★Con 76mm Header back Single Exhaust
Samco Sport Intake Arm
Drivetrain
Spoon 4.44 Final Gear Set
Spoon 1.5 Way Helical LSD set
Spoon Flywheel
Spoon Clutch Disc
Spoon Clutch Cover/Pressure Plate
Spoon Clutch Slave Hose
Spoon Release Bearing/Throwout Bearing
Spoon Drive Shaft Spacer Kit
Motul 100% Syn Gear Oil 75W90
Motul 90PA Mineral Differential Oil
Modifry Yellow Jacket Speedo Calibrator
Body Reinforcement
Spoon Strut Tower Bar
Spoon X Brace
Spoon Rear Brace
Spoon Engine Torque Damper
Spoon 4 pt Roll Bar
J's Racing Rear Strut Bar
ASM Fender Braces
L★Con Reinforced Front Subframe
L★Con Reinforced Rear Subframe Ap2
Suspension System
Spoon Full Spec Adj. Damper Kit (14kg Ft, 12Kg Rr)
Spoon Weld on Gusset Plate
Spoon Engine Mounts
Spoon Engine Mount Rings
Spoon Offset Roll Center Ball joint Assembly Front
Spoon Zero Bump Steer Kit Front
Spoon Zero Bump Steer Roll Center Adj Rear
Spoon Transmission Mount
Spoon Differential Mount Set
J's Racing Steering Rack Bushing Kit
Swift Stabilizers/Sway Bars 26.5mm Front & 26mm Rear
Eibach Anti-Sway Bars 31.89mm Front & 28.47mm Rear
Brakes System
Spoon Monoblock Brake Calipers
Spoon Steel Braided Brake Lines - Thermo Wrapped
Spoon Reservoir Tank Covers
Spoon Brake Duct Hoses
OEM Brake Disk Rotors
Endless CC-X Brake Pads
Endless CC-R Brake Pads
Hawk DTC-70 Brake Pads
Motul RBF600 Brake Fluid
Wheels
Volk Titanium Silver CE28 17X9 +35 offset
Volk Silver RE30 17X9 +40 offset
Toyo Proxes R888 255/40/17 (R-Comps)
Spoon Blue Light Weight Wheel Lugs
Exterior
Spoon Coupe Hard Top
Spoon S-Tai Bonnet/Hood
Spoon S-Tai Front Bumper
Spoon S-Tai Rear Bumper
Spoon S-Tai Rear Diffuser
Spoon S-Tai Front Fenders 20mm wider
Spoon S-Tai Rear Over Fenders 15mm wider
Spoon GT Carbon Wing
Spoon Front Stainless Grill
Spoon Hydro-Blue Wide Mirrors
Carbon Doors - 15lbs per door
Carbon Trunk Lid - 10 lbs
L★Con Aluminum Front Splitter
Interior
Spoon Steering Wheel
Spoon Steering Boss
Spoon Carbon Kevlar Bucket Seat & Rails
Spoon Reclinable Seat
Carbon Radio Delete pate
Bride Type RO Rail
Spoon Titanium Shift Knob
UKDM Ap2 9k RPM Gauge Cluster
Takata 4 Point Harnesses X2
Alignment
Camber Front -4 deg
Camber Rear -4 deg
Caster Right 6.0 deg
Caster Left 6.0 deg
Toe Front 0 deg
Toe Rear Total 3/16th deg In
Weight w/o Driver 2620lb
Old 12-13-2007, 12:41 PM
EriS2k's Avatar
WOW!
Great Bro! You need a MAG COVER ASAP!
Old 12-13-2007, 12:43 PM
Tolgahan Ures's Avatar
Very nice car
Old 12-13-2007, 12:44 PM
modMonkey's Avatar
WOW!
I agree! Nice job.
Old 12-13-2007, 12:49 PM
lazyjet's Avatar
Nice Spoon ftw
Drinks2k's Avatar
wow definition of a SPOON WHORE lol absolutely sick the amount of time/moeny that went into your S
Old 12-13-2007, 12:52 PM
AlexS2200's Avatar
Its more like a disease.
Old 12-13-2007, 12:53 PM
EriS2k's Avatar
Originally Posted by stevespai,Dec 13 2007, 01:44 PM
I agree! Nice job.
You Need Modified Mag On you CAR NOW!
Old 12-13-2007, 12:55 PM
AlexS2200's Avatar
Trying to get Sport Compact, but we'll see.
Old 12-13-2007, 01:02 PM
pointa-b-c's Avatar
Nice car, Alex.
Quick Reply: ★☆ 2004 Spoon S2000 Coupe ☆★
