Accusump install - block fitting?
Old Mar 18, 2010 | 05:23 PM
Bikey's Avatar
Default Accusump install - block fitting?
I did a search but it came up dry on this point - are any of the oil galleries on the block tapped (to allow directly plumbing of an Accusump)?
Thanks,
Ben
Old Mar 18, 2010 | 09:35 PM
X-RAYED's Avatar
I don't have an accusump, but I would think it could be plumbed in at the oil pressure 'sensor'.
Old Mar 18, 2010 | 09:39 PM
Bikey's Avatar
I believe that is a pretty small orifice (as least it is on a B series block). The Accusump needs something bigger - something that would support running -8 or -10 hoses.
Old Mar 19, 2010 | 06:26 AM
blackey's Avatar
It's normally done at the oil filter sandwich plate.
http://www.lpiracing.com/Canton-Oil-Input-...-2510p26303.htm
Old Mar 19, 2010 | 07:16 AM
Stratocaster's Avatar
I agree. A sandwich plate if you are keeping the OEM oil filter inplace. You can install a block off plate if you want a remote oil filter.
Old Mar 19, 2010 | 08:20 AM
Bikey's Avatar
Yes - I was planning a block off plate and a remote filter, just trying to avoid the "T" plumbing.
Thanks.
Old Mar 19, 2010 | 09:14 AM
You are stuck installing the T. Sorry. I had to install on too.
Old Mar 20, 2010 | 07:17 PM
robrob's Avatar
Don't use anything less than a 1/2 inch inside diameter line made for oil. General purpose hose will not support high pressure hot oil for long.
Old Mar 23, 2010 | 01:28 PM
EngineerX's Avatar
And don't forget a check valve.
I like the "jet engine" check valves sold at batinc.net over the Canton check valves.
When you see the inside of each check valve.... you'll know which should flow better.
http://97.74.103.94/files/cvalve.pdf
scroll down to pg# 4
http://97.74.103.94/files/accus.pdf
Old Mar 23, 2010 | 04:30 PM
Bikey's Avatar
I was planning on using a Summit one-way, which uses a teflon flapper - which seems a bit better than the Canton.
markforrester99
Feb 22, 2016 12:26 AM
turbo8765
Oct 9, 2015 06:19 PM
bruce0293
Jun 11, 2009 12:21 PM
daniel_ap1
Aug 18, 2006 02:50 PM
WongGahming
May 22, 2005 10:39 PM
