Oil Temp Sensor Install
Old Nov 19, 2012 | 06:56 AM
turbo8765's Avatar
Default Oil Temp Sensor Install
Is the factory oil pan thick enough to drill/tap for an oil temp sensor, or do I need to weld on a bung?
Suggestions for locations? Pics?
Old Nov 19, 2012 | 09:08 AM
tlee1234's Avatar
http://www.evasivemotorsports.com/mm...DDY-OIL-FILTER
this is what I used, Greddy Oil FIlter Block Adapter
Old Nov 19, 2012 | 10:23 AM
Vyndictive's Avatar
I used the sandwich plate design for mine. Did oil temp and pressure off the sandwich plate.
I used a glowshift brand. No issues.
http://www.ebay.com/itm/OIL-FILTER-S...27d83a&vxp=mtr
Old Nov 19, 2012 | 12:00 PM
krazik's Avatar
Administrator
the place the oil will be hottest is in the oil pan, so thats where I measured temp. What I had done was timesert the drain plug to make it M12 iirc and use the sender as the drain plug. It does mean the hole for the oil to exit is smaller so it takes a little longer for the oil to drain out. but the most relevant oil temp is the temp of the oil in the pan.
Old Nov 19, 2012 | 12:36 PM
SLINKYDOG's Avatar
i have a bung welded on the driver side of the oil pan.
Old Nov 19, 2012 | 03:59 PM
99SH's Avatar
I drilled and welded a bung on my pan. (the one on the bottom)
Old Nov 19, 2012 | 04:03 PM
turbo8765's Avatar
I think we have a winner... thanks for the info guys
Old Nov 21, 2012 | 05:40 PM
razzele's Avatar
You can buy sump plugs that accommodate an oil temp sensor.
This is the one I have been using-
http://www.demon-tweeks.co.uk/perfor...p-plug-adaptor
hopefully that will save you some nasty tig welding on cast alloy.
Old Nov 22, 2012 | 04:45 AM
robrob's Avatar
http://www.demon-twe...mp-plug-adaptor
I like this solution.
Old Nov 22, 2012 | 04:52 AM
turbo8765's Avatar
Here's an example of one on our side of the pond.
http://store.42draftdesigns.com/Univ...Plug_p_58.html
