LS7 S2000
Old Apr 10, 2010 | 04:00 AM
s13_ap2's Avatar
Wink LS7 S2000
Vids in Link
LS7 S2000
SUPER SICK!!!!
V8 S2000 forum
p.s. where all the haters at cause i know your going jump on this like white on rice in a glass of milk on a paper plate in a snowstorm.
Old Apr 10, 2010 | 05:37 AM
JackS's Avatar
Interesting car and I'm sure its a lot of fun to own but in reality its no longer an S2000. This car is now a very nice looking hotrod. Nothing wrong with that. You know the old comparison saying "apples and oranges" . If the S2000 is a apple, this car is an orange.
Old Apr 10, 2010 | 05:45 AM
madcowdk's Avatar
I appreciate the work that goes into something like this but something about it just seems wrong.
To each his own...
Old Apr 10, 2010 | 05:56 AM
doheboy6's Avatar
That is dope. I love it.
Old Apr 10, 2010 | 05:57 AM
04S2kSS's Avatar
Its hott....id drive it...
Dre
Old Apr 10, 2010 | 05:58 AM
bronxbomber252's Avatar
Would i do it... HELL NO!!!... would I take it for a drive given the chance... HELL YES!!!
Old Apr 10, 2010 | 06:22 AM
suzuka-blue-s2k's Avatar
Something I would never do to mine, but that is pretty badass! Ohh, and its suzuka!
Old Apr 10, 2010 | 06:23 AM
Sticky2k's Avatar
DAMN
Old Apr 10, 2010 | 06:49 AM
s13_ap2's Avatar
Wiki LSX engine
The LS7 is a 7,011 cc (7.011 L; 427.8 cu in) engine, based on the Gen IV architecture. The block is changed, with sleeved pistons and a larger 4.125 in (104.8 mm) bore and longer 4.00 in (101.6 mm) stroke than the LS2. The small-block's 4.4 in (111.8 mm) bore spacing is retained, requiring pressed-in cylinder liners. The crankshaft and main bearing caps are forged steel for durability, the connecting rods are forged titanium, and the pistons are hypereutectic. The two-valve arrangement is retained, though the titanium intake valves by Del West have grown to 2.20 in (55.9 mm) and sodium-filled exhaust valves are up to 1.61 in (40.9 mm).
Peak output is 505 hp (377 kW) at 6300 rpm and 470 lb·ft (640 N·m) at 4800 rpm with a 7000 rpm redline[citation needed] During GM's reliability testing of this engine in its prototype phase, the LS7 was remarked to have been repeatedly tested to be 8000 rpm capable, although power was not made at that rpm level, due to the constraints of the camshaft's profile and the intake manifold ability to flow required air at that engine speed.
8000rpm no power i can fix that put a kinsler itb cross-ram on it with a more apealing cam. FIXED!!! now lets shoot for 9000rpm
also car weights in 49.8 front and 50.2 rear
s2000 weight reference
Old Apr 10, 2010 | 06:53 AM
R_W's Avatar
R_W
Nothing short of insane!
Just hope its not out of an '07... those LS7s like to go pop. Bad batch of rocker arms, I'm afraid.
Personally, I'd have gone with an LSX. Insane motor. They have TT versions cranking 1000 hp on low boost, and around 1400 on high boost without breaking a sweat. Bit heavier than the LS7 though, but not by much.
I think I'd just buy the Z06, personally.
