Does this sound like seized calipers?
Old Sep 11, 2010 | 10:55 AM
S14 to S2k's Avatar
Default Does this sound like seized calipers?
This is sort of a continuation from my previous post with the rubberish burning smell...so today at the mechanic we discovered that the burning smell was actually coming from the passenger front brakes. they were extremely hot compared to the left and the pass. front wheel always got caked with brake dust faster than the drivers side. however, the brake burning smell started randomly a few days ago after the car sitting for a week.
When I was driving back, I noticed that the car would slow down on its own slightly faster than it should even in neutral, and even when i let go of the brakes at certain slight ramps the car doesn't roll back/front. there's no noise coming from the brakes when i'm driving though. does this sound like a seized caliper? what's the best solution to this problem, and if i do have to buy a new caliper (maybe remanufactured) how much do they usually run for ap2? thanks.
Old Sep 11, 2010 | 11:12 AM
240toS2k's Avatar
Feeling the caliper seems... painful. Check your wheels after a long drive is one hotter than the other?
When I had a stuck caliper there wasn't any noise either. Just 1 wheel getting way hotter than the other 3. I fixed it by bleeding the brake lines, air got into the caliper when I was fiddling around with it earlier. After the bleed everything went back to normal.
It wouldn't be a bad idea to check the rubber seals on the caliper, if they're still good you should be ok, maybe change the pads and machine the rotors.
Also your screen name is dangerously close to mine lol but mine was a S13
Old Sep 11, 2010 | 11:42 AM
NFR_AP2's Avatar
same thing happened to me on the passenger front wheel. it was a seizing caliper. i went to honda and ordered a reman and ever since i replaced it everything has been great!
Old Sep 11, 2010 | 04:07 PM
k1ng124's Avatar
Had this problem one time on my civic hatch, I changed the master cylinder and everything went back to normal.
Old Sep 11, 2010 | 05:48 PM
S14 to S2k's Avatar
thanks guys...yea the suspect caliper gets hotter than any other 3. so i guess the best thing to try is to bleed the lines first? if that doesn't work i guess i have to get a reman. caliper...does anyone know how much that costs anyway?
also can a caliper just get seized randomly? i mean i always had more brake dust from the suspected caliper more than the other but now i could smell it burning so i guess it's progressively getting worse? would bleeding take care of that?
Old Sep 11, 2010 | 06:28 PM
240toS2k's Avatar
Some guy on the forum was selling a full set of AP2 calipers for 150. Bleeding will only help if an air bubble is causing the issues. You could also try spreading the calipers like if you were changing the pads.
Old Sep 11, 2010 | 07:03 PM
S14 to S2k's Avatar
^thanks, nice sn to you too btw, lol.
how can i tell if bleeding will solve the problem? i don't really have tools so i can't really try much...i guess i'll have to go to a mechanic worst comes to worst.
Old Sep 12, 2010 | 06:12 AM
NFR_AP2's Avatar
reman from honda iirc is about 140 with a 20 dollar core charge so really its only about 120
Old Aug 13, 2013 | 10:11 AM
runmanrun309's Avatar
Did you get this fixed? And if so how? Same thing is happening to me. :[
BigDaveS2K
Dec 30, 2009 12:57 PM
hariku821
Apr 20, 2009 12:00 PM
scarab45
Dec 20, 2006 12:58 PM
MacGyver
Oct 14, 2005 06:25 AM
minboost
Dec 12, 2004 02:34 PM
