Brake Master Cylinder Float Sensor
Old Sep 19, 2010 | 10:51 AM
BallSackJack's Avatar
Default Brake Master Cylinder Float Sensor
The white floating sensor seems to keep going down which trips the BRAKE light, even though the fluid is near max and the pads have plenty of life. I'm not taking any hard corners either, just normal driving. I'll raise the sensor so the light turns off, but lately it's been coming back a few drives later. The brake fluid is fairly new ( < 8,000 miles). When I brake it sounds like something is rubbing (only while braking), and sometimes when I come to a complete stop it sounds almost like it's creaking. But from what I can see the rotors and pads are in great shape (I'm no brake expert though). Any input would be appreciated, thanks!
Old Sep 19, 2010 | 01:24 PM
Robert O's Avatar
The float sensor knows nothing about the condition of brake pads.rotors or calipers. It reads fluid level only. So,if your getting an intermittnet low level light you either one: intermittently have low fluid in reservoir ,which is unlikely ....or two: have a defective level sensor.If you have to raise it back up it's not doing its job.
That said..If you are experiencing a rubbing noise while braking ,you have either pad,caliper,or rotor issues or any combination thereof. Did you actually remove the wheels and closely inspect each brake unit?
Old Sep 19, 2010 | 04:27 PM
spets's Avatar
The float is known to go bad sometimes and not float anymore. You can try to find another one at a junkyard or something.
Old Sep 19, 2010 | 04:58 PM
240toS2k's Avatar
Or, pull the sensor cable and just check the brake fluid level when you check your other fluids. Mine broke 10k miles ago and I just unplugged the sensor to get rid of the warning.
Old Sep 19, 2010 | 05:51 PM
thank you everyone!
Old Feb 25, 2013 | 03:45 PM
ivgonzalez's Avatar
Any update on this topic? I don't want to spend the money on a new master cylinder if I can find a new float sensor.
s2kdarren
May 31, 2018 11:39 AM
ken reich
Jun 27, 2010 06:42 AM
thesilverbullet
Jan 17, 2010 12:28 PM
RobJ1
Apr 10, 2008 07:50 AM
TwiztedS2K
Sep 20, 2004 02:06 PM
